Post Info TOPIC: WDH Chain to E2 Conversion
Has anyone converted a roundbar chain type WDH to an E2 roundbar sway control WDH?
If so, could you provide opinions about the conversion, cost and performance.
From this, or similar...
To this...
Cheers, Richard (Dick0)
Yes I have considered doing it but I do have a concern.
Its not about the cost but the e2 bars seen to be narrower, and what would you use for friction materal to add to the existing bar.
I ordered the L-Brackets as a starter and will let you know what width bar will fit the brackets when they arrive.
This is now a work in progress.
ok
