Post Info TOPIC: Avan drop down bed
Avan drop down bed
My drop down bed comes down ok but will not go up. Fuses are ok. Any suggestions please.
Welcome to the forum Trevor, I assume the bed is in a Motorhome. Is the mechanism electric over hydraulic or is it raised on cables?
Check up limit switch
Laurie
Might be linear actuators?
The OP needs to give us more info,
Thanks for the replies so far. It is in an Avan Ovation motorhome. It is electric
I am a bit of a novice. Where is the uplimit switch and what is a linear actuator
We need to know about how the mechanism works.
If it won't go up, how do you know that it still goes down?
Post some pics of the mechanism.
It is a HappiJac brand bed lift. When I am not using my motorhome the bed is always in the up position. On this occasion the bed came down ok but would not go back up
Start pulling things apart, sometimes faults are obvious when you can see the mechanisms, Can you hear a motor sound when it's coming down? Is there any indication or sound when you try to raise it? Is it a 2 way switch that raises & lowers it? If there is a motor noise coming down tells you the motor should be o.k., if the motor runs trying to raise it you have a mechanical problem, maybe broken cables.
J. Price
A websearch gave a YouTube for an installation of a HappiJack bed lift.
Here is a link: https://www.youtube.com/watch?v=M5VzotGO0A4
This is USA video.  Towards the latter part of the video, it shows an electric motor that drives a number of cogs via chains and a shaft. The chains have similar links to bicycle chains. There are chains in the legs that raise and lower the bed frame.
Great video in that it perfectly explains functions and possible areas of malfunction.
