SmartBar Camp Creative
Post Info TOPIC: 12v power stations
12v power stations
Has anybody had experience with 12v power station (as opposed to battery boxes) shutting down when a 12v fridge stops due to being cold enough and then filling to restart. If so how did you overcome the problem?
"Seek wisdom not knowledge,
Knowledge is of the past.
Wisdom is of the future."
NAI Proverb
Might be the fridge, have you tried it with an alternative 12vdc source.
J. Price
Are you sure it's not the fridge stopping because the so called Power Station ( it's not able to replenish itself without plugging it in and recharging so it's name is a scam) is flat they have a small battery inside these units at a high cost and regular recharging, same as any setup.
Kebbin
As suggested the "power station" might be limited capacity to run the fridge. It does take a bigger surge of power to start a fridge motor again from stopped than when it is running. This might be too much for your battery unit to supply so it shuts down to save itself.
You would have to give us more details of the type and capacity of the power station and the fridge power rating to be more helpful. I see adds for those things with lots of items plugged in and think that they would not last long before being depleated running those items. Over hyped comes to my mind !
Everyone has pretty much said everything.
Just to clarify 3 fundamental questions to get started:
How many AH is the battery in the plastic box?
What model fridge is running off it?
Is it charged up daily?
This is a problem I was warned about by a friend who knew I was about to buy a power station, so i pre-empted the problem and am now about to buy a100amp battery and box for the backof the Ute. It worked out the a 300w station would not supply the run time that I'm looking for.
Thanks for the input it really helped with my decision.
NAI Proverb
Sounds like the OP has had the question answered to their satisfaction. I just wanted to ask what the difference is between a battery box and a power station? There were several uses of the term "so-called" in the previous replies. My impression has been that they're essentially the same, but the power station has a few more smarts. Possibly because it can input power directly from sources like AC and solar. Is that it?
What I understand is a power station comes rated as 300w power supply with every low lithium power storage, subject to price but has an inverter builtin and is capable of charging off 12v 240v or solar.
A battery box set up is a normal battery in a box (home made or bought) with whatever connections you require, but you need to add a dcdc charger and inverter.
For me it's now a better financial option to run a box with a 100amp lithium battery as I already have an inverter.
NAI Proverb
 Hi, that is probably a fair assessment. The power stations might have a few more  handy smarts and usually have outlets for most things you have too but depends on  what you pay really.  The cheaper ones are not as good in any respect as the  bigger very expensive ones. no
Looking at the power ratings they use, the model above with 300Watts,  comparing it to a 12V battery  that is only roughly equal to 25Ahr  at 12V; { 300W/12V = 25 AHr  capacity  }.  That is not enough to run anything for much useful time. Just forget all  those pictures of welders or  cookers or  high power things, even a fridge  at 5A only gets 5  hours. So do  not  be misled by  the BS. It would keep your phone going and  a small  light   for  a  couple of  days IMHO.  hmm
I use a Renogy 200 power station, has been great in the caravan to have power to move around and for small 240v devices definitely worth it when off grid
The Renogy 200 has a 15AH battery. Not exactly useful for a fridge.
yes very correct, only decent size lithium batteries are good for fridges, but these power stations do provide portable power for a lot of lower powered devices with many different connections , very handy piece of kit.
Not difficult to knock up your own with only the connectors you actually need.
26AH gel battery:
2.JPGThis is my portable power in my vehicle to run the fridge Li-p04 50Ah. Works for me & reasonably light.
D.L.Bishop
