SmartBar Camp Creative
Post Info TOPIC: Communication in remote areas
Just asking opinions on what nomads are using when travelling in remote areas in case an emergency situation occurs. Ive got a PLB and an iPhone with Telstra for better coverage. Planning leaving on a 3-4 month trip mid July up thru inland NSW & QLD then across to NT then north to Darwin then back down WA coast back along the Nullarbor etc Appreciate your thoughts Ron
 Have 2 mobiles on 2 major networks, hedging my bets.
Other then that I do not think to much into it to be honest, the more think, the worst it becomes.
PS, as our resident Chief will tell you "smoke signals".
It really depends on how remote you want to plan for. Someone else can chime in on satellite options if you want coverage anywhere.
Other that, as Radar said, two phones on different networks.
Telstra or Boost for one (not other Telstra resellers) and Optus or resellers on the other. I don't know if iPhone is any better than other phones for reception, but Telstra gives a blue tick to selected phones proven to work better in poor signal areas. If you want better coverage an external antenna helps as well as height. You can set up wifi calling (better with a mobile modem) and hoist it up a tree for greater coverage.
For real emergencies (000), the phone does not need a specific network (or even a SIM card) to make emergency calls .... as long as it can get signal.
Apart from your PLB a two way radio can also get help. Range depends mainly on antenna and height.
A few options:
1. UHF radio but that depends on relay ability and hope someone is listing
2. HF radio not cheap but will get you coverage.
3. Sat phone These can be rented. From memory Telstra rents then and so do other places.
4. A sat phone case system for your iPhone. Not sure if there is one for Android
All sensible backups for the PLB
Note a sat phone or HF radio will get you total coverage
Always handy to have the emergency contact numbers for each state RFDS - Here
A UHF really should be part of every caravanners equipment fitted. Sure there are times when you may get no resonse....but usually there is a road train or another clued up traveller about...and a call for help will not be ignored.
Download the australian radio UHF channel frequency /usage site and check what the OZ wide emergency channel is....and also the repeater channel and how to use it. Then set your set up for open scan and leave it on when travelling so you can moniter it. And as for those poor precious souls who cant put up with the language on truckie channel which happens from time to time...well its like this ...tolerate it or die....
Cheers  Keith
Nuthin is ever the same once I have owned it ......
I think a PLB or satphone would be a lot safer if going to remote areas. Mobile phone coverage can be a bit random, even close to cities. We live in a mobile black spot. We can just get range in certain areas at home but only with the Telstra network and as soon as we leave home there's no range on any network for most of the drive to town.
We have both Optus and Telstra , you will be surprised in a lot of out back places that Optus works but there is no Telstra signal .
After that we use starlink wifi calling works every where .
We use Telstra "Blue Tick" phones - if there is any signal available, we can get service.
Always have UHF radio mounted in vehicle and we each carry a small hand-held when walking.
First the it's best that your phone has band 28 700Mhz this is the best rural coverage frequency.
I truely wonder why people are so dependant on telephones, until the mobile phone became so readily available, the majority of us who travelled pre mobile era, we travelled up the guts across the top and bottom, up and down the western and eastern states including remote areas, with paper maps plenty of food and water. We knew if something went wrong stay with the vehicle.
1972 on one trip from where I was working in Exmouth WA to Adelaide, we were out near Iron Knob when the car **** its self, got towed into Iron Nod by another traveller around 9pm, just after that on of the blokes I worked with Exmouth saw us and stopped to check us, he took wife and son on to Adelaide, while I waited for the holden dealer to open in the morning, gear on the distributor was replaced and back on the road again.
With todays modern vehicles it not that simple, so RAA, RACV, NRMA etc membership is the most important tool you can have.
Thanks everyone for your inputs
Much appreciated
Ron
A PLB is the cheapest EFFECTIVE method of getting help in a life threatening situation in remote areas. About $300-$400, good for 7-10 years and no ongoing costs. Completely portable. They are also the easiest to use. Put the arial up and press the button.
If activated, there WILL be a response to a PLB, generally within a couple of hours ANYWHERE in Australia. They also work anywhere in the world.
For the best results, they must be registered at beacons.amsa.gov.au/registration/
Mobile 'phones and UHF radios can NOT be relied upon.
HF radio is expensive and requires significant knowledge to use effectively. In the event of an accident, they can be rendered useless.
There are also devices such as "Spot" satellite devices with limited 2 way communication capability that are useful, but they will cost more than a PLB.
Then there are satellite phones with lots more capability at significantly higher cost.
My advice is to get a PLB if you ever expect to be out of mobile telephone range (and you can not travel this country and not do that). If you want more that that, buy or rent a satellite 'phone, as well.
 Our approach and experience exactly.
l2sfbc.com/why-starlink-isnt-an-emergency-response-system-for-vehicle-based-overlanders-offroaders-and-outdoors-people/
Starlink also isnt as portable as a satphone or distress beacon. In fact, without a vehicle, its really not portable at all, and thats before you consider the power sources. Speaking of power, well youll want a decent size 12v battery to keep Starlink going, and a means to replenish the battery such as solar. In contrast, you dont need to worry about that with a distress beacon, and a satphone battery lasts a long time, and can be recharged with a small solar panel, or maybe a USB power pack.
Starlink is also far from robust. The dish can be damaged easily, and the wifi system isnt designed for outdoors use. Again, contrast that to a satphone, satellite communicator or distress beacon.
-- Edited by Peter_n_Margaret on Saturday 11th of May 2024 03:37:28 PM
in this day and age if you are near any large city or on a main road, you should be able to get a signal so unless your planning to get well off the beaten track, you should have no issues but a uhf radio is a good back up for the occasional black hole. was not all that long ago we use to travel all over this country and we never even had CB radios let alone mobile phones
the smoke signals still work, if you are in real trouble out back, set fire to something (like rubber/plastic) an see how long it takes for someone to come and find out what is going on.
There are many places on main roads without mobile 'phone reception in this country, like 90% of the Stuart Highway, and even significant parts of Highway 1, particularly in northern Queensland and the NT and that is before you consider anything less "main".
www.telstra.com.au/coverage-networks/our-coverage
And if you have had a "small" incident, like loosing control for a moment while avoiding a kangaroo, wrecking your UHF antennae on a bush will render that useless.
-- Edited by Peter_n_Margaret on Sunday 12th of May 2024 05:34:36 PM
Have a look at ZOLEO, I have just done a trip thru some of western QLD National parks. I found Zoleo to be faultless and cost affective.
Zoleo is a global satellite texting system and offers much more, text any mobile in the world when out of cellular range and receive a reply
After being able to tell someone who is capable of arranging the help you need in an emergency, it is also necessary to be able to tell them EXACTLY where you are.
This can be done with an app on a smart phone using the 'phone's GPS, but if you are out of mobile reception, you will need something else.
The PLB does this, UHF and HF radios do not.
www.triplezero.gov.au/triple-zero/smartphone-applications
This is the free Government app to allow your smart 'phone to send an accurate GPS position when you call 000.
It requires a mobile signal to work.
Knowing your exact position is critical for emergency services to find you quickly, especially out of towns.
Zoleo my friends,also has SOS function which will contact emergency services with your GPS coordinates and much more. Stay in touch with friends and family at all times no mater where in the world or Australia you may be
Google it.
You can NOT contact 000 by SMS.
You MUST send the SMS to 0423 677 767. Not a number that most of us will ever remember.
www.infrastructure.gov.au/sites/default/files/instruction-sheet-2-3-sms-relay-call-to-emergency-services_2.pdf
For goodness sake, PLB is clearly the the ONLY option when travelling in isolated/ non mobile reception area's if you are serious about yours and your loved ones safety. $300 is cheap.
We acknowledge and pay our respects to the British and European Elders past and present, who introduced civil society and prosperity to Australia.
There is a difference between emergency rescue and getting help.
I agree that PLB would have to be the most reliable if rescue is the goal. But you may prefer to get someone who will help get you and your vehicle back to civilisation rather than be airlifted by a helicopter, leaving everything you own there. In that case some form of two way communication would be most desirable.
 Aussie1,  I suspect this has been highlighted in a WA news item this evening. A real PLB recovery.
If it works no
Based on what I see here, a combination of things is really best for truly remote travel.
The PLB for precise location, and a satellite phone for precise information of the emergency.
That way, the right things turn up at the right place to make the necessary recovery, giving the highest chance of the best outcome.
A bit expensive, yes, but a small investment in the safety of all concerned.
-- Edited by TheHeaths on Tuesday 14th of May 2024 08:55:19 AM
Regards Ian
There has just been a PLB activation near Co-ck-elbiddy on the Nullarbor. On Facebook for those that use it.
www.facebook.com/WA.Police/videos/1679144035955774/
The vehicle had been bogged for 4 days and they were running out of supplies. They activated their PLB and a chopper was sent to investigate. Once they had been sighted, 2 way communication was established with UHF. A ground vehicle arrived and snatched them out of the bog.
All very quick and painless.
There would be no charge for this service.
ABC News report.
www.abc.net.au/news/2024-05-14/couple-rescued-after-days-spent-bogged-on-nullarbor-track/103845130Cheers,
Thanks everyone for your comments on this important issue.
A friend & his wife were rescued by a couple of police from Hughenden when he had no drive when out at Moorrinya NP (south of Torrens Creek). As he was in a remote section of the park he set off his PLB & it wasn't long before he was on his way. One of the police was an outback mechanic - used a rubber band to make an O ring for the end of the transmission's selector lever!
jjellfern, regarding the Zoleo, can you just take the plan when you go out travelling in more remote areas? Or do you have to take it out for a year or more?
I've noticed that Annaconda sells them.
So far I haven't had the need to utilise one of these but realize I should get one as I'm not as agile as I was a few decades ago.
