Post Info TOPIC: Does the sound from your Van/RV TV speakers drive you crazy?
There's a fantastic solution - I have a Sphere 21" that speaks thru silver paper
with a sound more like a $2 kids toy. So bad in fact that I rigged it to run thru the
in-house radio - trouble was the sound was from behind and above and somewhat
disorienting relative to the picture.
Anyway I imposed on the bride to let me spend $160 on a SOUNDBAR.
https://englaon.com.au/products/englaon-12v-bluetooth-soundbar-for-caravan-tv-e-test?
Well to report - 2 minutes to plug and play - further 15 to take advantage of the comprehensive
accessory and mounting hardware to mount flush onto the bottom of the TV.
A very professional looking unit
And the sound? My caravan is a studio now filled with absolutely first-class sound at
whatever the volume!!
One purchase that far outweighs cost and convenience in performance and ease of install.
VERY HAPPY.
B
Turned up will certainly frighten the wildlife. But I'm selfish!
Off thread and knockers start here now.:
Plenty of small good quality speakers around you can use as well. And you can take them elsewhere to play music from.
I'm using spotify on my mobile and connect that to Bose headphones, awesome quality sound.
Hi,we had the same problem in our Jayco c/van,useless speakers just above your head when sitting in the lounge part .Tv is an RV Media.Cured it with an AVTEX Sound bar ,its only approx 450mm x 50mm x 60mm ,sits under the tv and sound is fantastic.
Cheers Andy.
My Englaon 32" tv has a very acceptable sound. No issues.
Cheers, Richard (Dick0)
I have fitted separate speakers to all our TVs in the house and the camper. Just take the speakers from one of the many radio/ DVD players we seem to have around the place and wire them in place of the crap TV ones with a couple of plug connections. I can also locate the speakers closer to where we sit.
I guess i am too tight to buy an accessory that should not be needed to make the TV acceptable. But it does vastly improve the sound. The speakers do not need another power source either like most sound bars.
jaahn
We use our portable Bose speaker, great sound quality and can position it anywhere, so the sound isnt too loud for those who maybe near us on a still night
-- Edited by Brianvicki on Sunday 21st of April 2024 10:48:08 AM
Cheers Andy.
 The Engalon is only $160 or thereabouts - and plugs into 12v outlet.
Very convenient.
The Sphere TV is about the worst sound that I have ever encountered.
Frosty
We have been using a set of computer USB speakers for a number of years, take up very little room and perform very well, best of all about $40.... tried using the aux port of the radio as speakers are very good but the power draw with TV and Foxtel running as well was more than I wanted to use ...
We use a speaker that I also use for my I pod, had for many years, good sound.
Dick.
