Post Info TOPIC: Thetford toilt water running
HI all, if anyone has any ideas. I have a thetford casset toilt, it also has a SOG vent valve fitted, As with operation of toilet when fron sliding valve is opened
the vent fan switches on, You depress pump switch on the toilet, quick rinse of bowl, use toilet ,flush, cose valve.
However all of a sudden ,lift up lid, pull sliding valve to open , the pump begins to pump water through the bowl. only way to stop it is close, front slide valve, pumps runs for a while then
shuts off, you then have water in the bowl. Or switch of main power to CV water pump, use toilet then switch on pumps to flush.
So it appears when i disconnected one of the wires to the SOG vent pump, the problem went away. Reconnect the SOG vent pump, problem comes back. Not sure if Sog pump
is working , so next thing to do is put poer directly to it see if moter works. If so something is wrong with Sog to Toilet wiring, Anyone any thoughts, perhaps someone may have a witring diiagram.
Thank yous in advance
Keiron
