SmartBar Camp Creative
Post Info TOPIC: Waterproof mats for shower
Hi! What do you use on the floor of your shower/toilet combo to keep floor dry for the next one to use the toilet.
Never having yet had an onboard inside shower (only external) I can only imagine that a slatted base would be required. Either a rubber doormat type or wooden slats perhaps. Most important is good drainage. Multiple drains, one in each corner, avoids puddles when camped on anything but perfectly level ground. Any type of mat would need to avoid preventing drainage.
A well drained shower base would probably dry more quickly without having any sort of mat on it?
Just thinking aloud. You'll probably get inundated with a variety of brand name mats specifically for the purpose now!. :)
Welcome to the forum.
A Nomadic Life (Current)
The Big Trip (2008/9)
We had the Combo in our Destiny,all we did was wipe the walls n floor after a shower.
Chris & Sharyn.
Tea Gardens. NSW.
We use a microfiber bathmat from Aldi. Thick, soft and absorbent. It helps if you towel dry in the shower recess prior to stepping out on to floor.
An El Cheapo rubber mat with bumps on its undersurface so water can drain from underneath does the job. Cheers
    In the shower?
    Or outside to step out onto?
We use a timber slatted one with rubber feet.
Cuppa wrote:
 In the shower?
 The Aldi mat is suitable for in and out of shower recess, although we use it outside.
What does everyone think about using a dish drainer mat in the combo. Thanks
-- Edited by Sterling on Wednesday 30th of August 2023 03:56:01 PM
If shower water is due to more of a mould issue, get a Raven 200mm squeegee, longer not so good (it's also good for car windows in the morning) to remove splashes & condensation.
We live in an extreme humidity environment & to minimise mould we squeegee all shower surfaces, & also then put the extractor fan on.
Nevertheless we still get a bit on mould, just how it is.
It took me a while to get my head around this post.
But when I read it again tonight the penny dropped. The issue is about the floor of a COMBO Shower Toilet.
Having a separate shower & toilet in our van, a wet shower cubicle floor is not an issue although when we first got the van we used a purpose made rubber shower floor mat that had suction caps on the bottom to keep it in place.
We just wanted to stop the fibre glass floor from scratching.
Eventually just binned it because it was a PITA taking it out to dry and guess what, the floor is not scratched after 23 years!  I think that you would have the same issue with any mat & might be better off with some sort of squidge mop & perhaps an old towel to dry off the floor after use.
 We had a Jayco Freedom with a combo and did the same.  We showered one after the other and the last wiped out the entire combo with a super soaker cloth. This way the combo was cleaned regularly and was always clean.
Cheers Dodg.
Thanks all. I think I will stick to the squeegee and towel dry the shower. Happy travels everyone
If you are having a shower with water, the floor is going to get wet, water is like that, it wet everything.
 Have some old half towels and wipe the shower out after use.
From my experience worn towels dry quicker,  much easier to manage in on those cold or wet days.
