Post Info TOPIC: Foam for the Interior Vent of an Air Command Air Conditioner
Black Foam is about 40mm x 12mm by 1.6m that cool/hot air travels thru for temperature control in the caravan. Local Clarke Rubber do not stock this type of Foam anymore.
Suggestions on where to purchase.
Thanks
China, that is where I get everything now, gave up on buying from Australia ever again.
Ric - The Eccentric One
You could try a Godfrey's store. I have got filtering material there
Try Bunnings thats where I got mine from
Thanks Will Follow Up.
Welcome back rodnirene, it's been a long time between drinks.
Bunnings - Interlocking foam mats. Cut slightly over your required size and it will fit quite smug. I didn't use any glue.
Thanks for your replies. Have ordered this foam.
www.ebay.com.au/itm/234657116723
