Post Info TOPIC: Retreat Brake Light
Retreat Brake Light
I have a Retreat caravan with the triple lights each side at rear. All are working except for one of the brake light led circles in one light. Anyone experienced this and have a fix. Also how do you remove the light assembly to get at the wiring. They are ledaotolamps and have no visible screws. Thanks in advance.
Steven
Welcome to the Forum.
First check that the wiring is functioning properly if you can.
Whilst not familiar with "Retreat" most caravans have the three LED lamps behind a snap fit moulding/frame.
The frame surrounding the lamps can usually be prysed off with a nylon (plastic) cap removal tool (looks similar to a wood chisel). Look at picture of tools www.ebay.com.au/itm/285289567140
There should be screws visible to remove lamps.
-- Edited by Possum3 on Sunday 18th of June 2023 07:01:20 PM
