Post Info TOPIC: Steep point WA
Steep point WA
Anyone done steep point recently? How rough is it? Thanks
Hi Cassie63,
This is from middle of last year (2022)
Regards,
Ian
Hi,
We did the drive to Steep Point today, (Fri 5/6/2022) and the following may be of interest if anyone asks the Office staff about it.
We had a stock standard 2020 Toyota Landcruiser V8 diesel auto.
We left at 8.30am and got back at 6.00pm.
We tend to smell the roses but you would need to allow at least 8 hours at a minimum.
The road is corrugated!!!
There are a number of new long drop toilets out at Steep Point and the various camping areas but nothing until you get there.
There is effectively no mobile service for the whole trip. You may fluke one bar at Steep Point itself but cant rely on it.
You will need to have an air compressor to re inflate your tyres for the return trip.
DO NOT ATTEMPT THE TRIP IF YOU CANT LET YOUR TYRES DOWN AND RE INFLATE THEM.
YOU WILL GET BOGGED, IT IS VERY EXPENSIVE TO BE RECOVERED AND YOU CAUSE UNNECESSARY DAMAGE TO THE GRAVEL ROAD!!
If you have a uhf or phone antenna on your vehicle, wrap some electrical tape around where the antenna screws in or has any joins.
We stopped for morning tea (at the pay station), lunch (at Steep Point) and afternoon tea (at the pay station again)
The trip, with excursions to Thunder Bay, The Blowholes, Nord 6 monument and, of course Steep Point itself, was approx 350 km.
Be mindful of your fuel consumption as you will be in 4WD and soft sand. This could increase your consumption by up to 30%.
It is highly recommended to reduce your tyre pressures to around 24 psi (165kPa or 1.65 bar) to 26 psi (180kPA or 1.8bar) as soon as you leave the bitumen on the Useless Loop Rd. This gives a much smoother ride, is kinder to your vehicle and helps prevent damage to the road surface.
At this stage, 2 wheel drive or high range 4 is ok
There is a small, approx 5 km, length of bitumen road amongst the corrugations and if you have locked your hubs in, you may need to unlock them until you get back on the gravel.
If so, remember to lock them in again.
When you reach the paystation, it is essential to stop and reduce your tyre pressure to, at most, 20 psi.(138kPa or 1.38 bar)
If not already in high range 4 wheel drive, do so now.
If this requires hubs to be locked, do so now.
When you reach the T intersection, you turn left (road to the right is locked gate and no entry) and this is the start of the real requirement for high clearance and 4 wheel drive.
No real need for low range unless you think you need it.
High range 4 wheel drive and 3rd or 4th gear (held in an auto - not sure in a manual - long time since I have driven one!!)
Keep your wits about you as it is a narrow, undulating, winding road with limited forward visibility.
Keep your speed down as the sand bumps, especially as you have low tyre pressures, will cause the vehicle to wallow.
Also avoid any sharp turns(again because of the low tyre pressures).
We did not go to False Entrance on the way to Steep Point.
We did go to Thunder Bay, The Blowholes and Nord 6 monument and believe that it is easier going to visit these on the way to Steep Point than on the way out.
These are really worth seeing.
As it turned out, we ran out of time to visit False Entrance on the way back. It probably would have added approx 45 mins to our trip and, as it was, we only just got back before it was getting dark.
You will need to re inflate your tyres, up to 24 to 26 psi at the pay station on the return trip and unlock your hubs.
Reinflate tyres to your normal level when you get to the main bitumen rd.
If all the above presents you with no problems, go for it!
It is a great trip/destination.
Did I mention that the roads are corrugated!!!!
You don't have to know everything, you just have to know someone who does!
Thanks. Much appreciated, will be going out there in acouple of days
 Walk in the park for your 79! Enjoy. Cheers
Cassie, Remove false teeth and tighten bra straps, by the sound of it.
Completed steep point today, very corrugated. Tyres down to 18 psi H4 second gear most of the time. Did thunder bay first and drove around the cliff to steep point. Left camp at 7.00am got back at 4.00pm after a swim.
