SmartBar Floriade Darwin International Film Festival Goodlife RV Resorts Celtic Fest VisitLockhart
Post Info TOPIC: Jacyo Conquest 12V lights not working properly
Hi there, having trouble with my led lights, when i press any of the light switches the light comes on for about 2 secs max then switches off, if i press the "all off" button they all come on and then off after 2 secs, this happens even when 240V is connected to the motorhome. Hoping someone out there can assist??
Thanks, Tim
Unfortunately I can't recall what the procedure is but if you Google the issue, the answer is there.  I had one light that would do what yours are doing and by following the instructions mine now works again.  Perhaps I should have written it down for next time it happens, but I didn't.
This little saga may help if it's similar to yours/. The chap with the Jayco lights problem finally found the fix.
www.jaycoowners.com/forums/f41/lights-turn-on-and-off-on-their-own-77765.html
A Nomadic Life (Current)
The Big Trip (2008/9)
no worries, thanks anyway.
Hi Tim ,all the light switches i`m sure you know? are bluetooth , no wires ,small batteries in the back of the switch only  . Just prise the front plate off  Can`t help you solve this problem ,speak to a Jayco dealer. In our previous 2018 Journey caravan some of our light switches refused to work (just a quick flash on the switch plate) when the temp got to below 2deg .Soon as it warmed up ,all good again .Try replacing the batteries in the first instance .
Cheers Andy .
-- Edited by AndyCap100 on Wednesday 19th of April 2023 10:02:20 AM
