SmartBar Floriade Darwin International Film Festival Goodlife RV Resorts Celtic Fest
Post Info TOPIC: TV tunning
TV tunning
Having a bit of trouble tunning the ditigal TV. I wind up the wind guard, turn the tv on, go to menu then click on auto tuning but no hits. Others in the park appear to have their tvs working. We are in amongst the trees so maybe signal not getting through the trees. We do have SAT tv but no hits either due to tree cover. Maybe I answered my own question. Trees
Hi Cassie,
Is the Aerial amplifier turned on? It's easy to overlook. Have a look behind the TV - where the aerial lead appears. There should be a LED on, if not, there should be a small press button there.
Is your aerial facing the same way as the others? May need turning.
FMC
Check aerial amplifier is on, also the DTV antenna app on your mobile phone is handy to find the best direction for location.
Trees not normally a huge problem for TV
Darian Leckie
Thanks, my fault, all fixed. I plugged the aerial cable into the hole after it vibrated loose.
 Vibrated loose.  Does that mean you travel with your TV in the bracket. I suggest its better to put it away while travelling. I cant see any other way it could vibrate loose.
shakey55
Its mounted on the bracket and strapped to the wall
