SmartBar Floriade Darwin International Film Festival Goodlife RV Resorts Celtic Fest
Post Info TOPIC: SNORKEL TEST FAIL
SNORKEL TEST FAIL
Hi, i have a snorkel fitted to our bt50 and on our last trip the induction/air noise i usually hear suddenly stopped, when i got home i partly placed a thick piece of cardboard across the top of snorkel then slowly covered the whole thing. There was no suction at all, sound of engine didnt change and ran as normal.  I cant find any obvious air leaks such as the join in the guard,  and where it enters the air box seems ok.  Hoping to get some other things i may look for please.  The car runs and even idles ok, and no warning lights on . THANKS .
If you calculate the size of your engine, the RPM, compression with in general a turbo. It is a bit of an eye opener the volume of air that has to get through these things each minute.
Inlet manifold leak?
That air is coming from somewhere.
Has your air filter collapsed,?
J. Price
Not to forget the air box on the under side of the air filter has holes in it to drain condensation. So it will never be 100% sealed.
i placed my hand over the snorkel today and felt almost zero suction. Off to the mechanic AGAIN.
Any different if you rev it ?
i just tried that now, there is quite a bit more suction. Why is that so?
the higher it revs the more air it needs , so it must be getting air from somewhere if not thru your snorkel.
Theres a hell lot of volume for engine to use before you get any suction or vacuum!! Theres only a few joins . Its not hard to check ? If your not ever going in deep water ? I wouldnt worry too much . Except air leaks in engine back sucking in hot air .
im off to cape york ,doing the old telegraph track that has a few water crossings in april. The one join inside the guard/panel was a little loose which i have tightened as well as extra silicone at airbox/filter entry. im a little worried because other 4wds ive had, stalled the engine at idle revs. The hoses all look as new. thanks for the suggestions. Air filter was change at recent Mazda service.
-- Edited by cobberdog on Sunday 15th of January 2023 12:11:48 PM
