Post Info TOPIC: moisture meter update
hi folks,
can anyone advise on moisture meters? the last thread is a few years old. i would like advice on what brand to buy and why. how much should i spend? caravan specific use. what are the acceptable readings? our caravan is 2019 model, jayco, which i got advice about a water leak, but now thinking of the future and general moisture issues. safe travels to all.
shane
Branding is relatively unimportant - cheap one at the big shed should suffice.
There should be no moisture present inside the internals of the timber paneling in cupboards along bottom corners of walls of cabin and any/all boot storage areas - also little black ants can be an indication of unacceptable moisture within walls.
I agree with Possum, go for Bunnings cheapest.
thanks guys,
I'll keep an eye on those areas possum.
shane
Here is a topic which has some good advice by a now banned but helpful member on here. cry
The post was actually from Angie, his good wife.
https://thegreynomads.activeboard.com/t64770698/damp-or-moisture-meter/
-- Edited by Ivan 01 on Monday 26th of December 2022 08:34:23 PM
Welcome to Biggs Country many may know it as Australia
This members posts may contain;
The actual truth
If offended, scroll on by.
Moisture levels in what is considered dry timber should be below 12%. Timber will absorb moisture from the atmosphere naturally and will increase the percentage in humid or wet weather and lose moisture in dry conditions. Typical readings taken inside a dry dwelling including a caravan would usually be between 8 to 11% depending on the level of moisture in the air at the time. You can spend a lot of money on moisture meters, and if you are using them professionally then it is wise to buy a good one and spend the money, but for casually checking your own van, generally a cheap one will give a good enough indication if you have an issue or not. The firms I worked for had expensive models but since retirement I no longer have access to those so bought a little Aldi model which does the job more than adequately even though it may not be quite as accurate as the more expensive models. They only really read conductivity after all and convert that into moisture percentage and are good enough to indicate if there is excessive moisture present.
Greg O'Brien
Be aware of course that your van has an alloy, not wooden frame, so moisture meter may be of limited benefit.
Regards Ian
Many vans making use of composite panel construction still have wooden floors, cupboards, fixtures and other fittings and trim.
The actual truth
Alloy framed and composite vans can also have water issues.
A moisture meter will not just read timber. Even my little Aldi one has different modes for different materials. I have used them successfully on concrete and gyprock for example.
Alloy framed vans still have internal linings usually made of ply which will give a reading around the water ingress site. Composite vans have various fittings inside often made of ply substrates that a reading can be obtained from and some panels have a ply inner face.
They are a very handy guide for tracking down an issue and mine cost me a wallet breaking $24.95 which really isn't going to give my bank manager heartburn for a handy item.
Greg O'Brien
thanks again guys. some very useful comments.
travel safe and happy New Year to all.
shane
I think why alloy or any conducive material ? Is due to the resistance of timber ? If its measured that way?
