Post Info TOPIC: zwea stove
zwea stove
typical first trip away and the stove will not stay lit unless I hold the know in . help
-- Edited by maids on Friday 2nd of December 2022 11:07:35 AM
VW Campervan LWB 35 2007
The stove has a thermostatic control designed to turn off gas when no flame present to heat the little thermostat - usually holding in knob for 10-15 seconds will actuate full gas flow. If this is not happening after 15 seconds the control isn't working as designed, usually this is because there is grease or grime causing the problem. The burners should only be cleaned/changed by licenced gas fitter (although I have done mine several times).
homeguides.sfgate.com/replace-thermocouple-propane-stove-29063.html
on the nail the others work so needs a clean thanks
