Post Info TOPIC: Shower head - thanks Mein
Thank you Mein for your excellent suggestion of this shower head:
Ebay $15 shower head
It is brilliant! It really feels like showering in a warm rain strom and my 15L of water lasts much longer. No doubt the tiny jets will need more regular cleaning given I usually shower in dam water but, as the shower head may be disassembled, that is a small price to pay.
Mike,
Any idea how many litres per minute on full? No details on the eBay sellers site.
Regards,
Ian
You don't have to know everything, you just have to know someone who does!
On it's "rain" setting I guess around 3L/minute, with my 12V pump.
I find that with my 15L bucket of shower water I tend to get a little bored before it runs out.
Warning... Mike, Clicking onto your Link for the Shower head , "AVAST my virus checker came up with a Virus warning as soon as I saw a picture of the shower head and asked to do a Virus scan.
The problem was URL: Blacklist, if I read it correctly.
Status: Online
It just links to another Grey Nomads thread. No issue that I can see.
Your virus checker is showing a false positive Peter.
My link points to another GN thread in which Mein posted a link to a shower head on eBay, all is good :)
You're welcome!
"No doubt the tiny jets will need more regular cleaning"
I clean mine with a toothbrush, roughly once a month.
And, after 18 months use, the switch that toggles between spray modes became quite stiff so I bought a new head.
Mein wrote:
You're welcome!
One way of avoiding cleaning the microjets often is to use common steel wool (flat square type), curled up and rammed into the shower handle that acts as a filter.
Once a year replace the wool and backwash the shower head.
I have an instant hot water unit and the back pressure helps even out the heated water flow.
Full cold water pressure flow is just under 4 litres minute compared to 9 litres for a standard shower rose. A great water saver.
Cheers, Richard (Dick0)
Mein wrote:
You're welcome!
 I hope that you don't use your own toothbrush.
If it is build up from hard water stick it in vinegar overnight.
I bought one of these Ebay shower heads, and unsurprisingly it doesn't fit my shower head bracket. I'm going to have to source an alternative bracket. Any chance of a pic of your bracket?
This is the one I'm using:-
https://www.mitre10.com.au/interbath-raindrop-handshower-wall-mount-chrome
I expect this one would also be suitable:-
https://www.ebay.com.au/itm/134152958758?
Funny thing about a shower head for camping is not the type you would use at home ? But the cheapest to a point as in smallest works best . The little pump and pipes in van are not even half the size at home ! Plus you go through too much water !! I like the type with tap on head . So can be turned off after getting wet then lather up with body wash or soap . The finer the jets the better too !! Then the cheaper plastic is best . Lightweight and is not a projectile, damaging things if it falls etc .
