Post Info TOPIC: VW Crafter Window issue
Does anyone have theses windows?
This one does not shut properly bottom right any ideas please
-- Edited by maids on Thursday 17th of November 2022 06:14:18 PM
VW Campervan LWB 35 2007
I would have a body builder / panel beater to have a look at that.
It may have been damaged at one time although hard to tell from the one picture.
Welcome to Biggs Country many may know it as Australia
This members posts may contain;
The actual truth
If offended, scroll on by.
Most of that style of window has frame and window moulded to suit/fit together.
The problem is most likely caused by something lifting window up on bottom track, check that track is straight and not warped, or window has something protruding underneath.
Sorry, but I can't see anything wrong with the window, only that the sliding door is open a bit.
Have you tried a VW Dealer? Maybe another pic a bit closer to the window please Maids.
Cheers Bob
Make it Snappy......Bob
will send a pic later. we are in the middle of getting sola on.
On another note would not go back to the dealer. they had our van 6 weeks and would not fix a leaking fuel hose instead wanted to fit a new tank
Is the black button just below window a "Push-in" lock? If so, that may be cause of window lift. Side widow whilst holding finger on "Pin" to determine if it touches when sliding window closed.
 Wow we never saw that and have no idea what it is.
The van is being fitted with Sola and not here ATM but will certainly check that out
 it is the door lock not window lock
