Post Info TOPIC: 2016 Dmax
2016 Dmax
2016 Dmax 4 door new to me, can anyone help.
If you have 12v from battery to the tub can you tell where it entered the tub. It only has 2 gromets in the front but I think that maybe double skinned.
Thanks
Living on the Gippsland Lakes Victoria.
ARB or similar should be able to tell you where they mount battery in tub and how.
I found a video on U Tube www.youtube.com/watch
Thanks
 Hi Jaybird,
My 2016 dmax has a 12volt Anderson plug mounted just inside the tailgate.
The cable to the Anderson is run thru the tail light cavity and joins with the cable that supplies the Anderson I plug my van fridge/battery charging into. That cable is run to the engine bay through the chassis rhs, under the car.
So mine is not wired through the grommets, yours could be.
Chris & Sharyn.
Tea Gardens. NSW.
Thanks Guru, I'll investigate that.
