Post Info TOPIC: Satking controller .
Satking controller.... does anyone know how to turn on the round disc like controller unit , was working ok until it was unplugged then plugged back in again , now the LEDs dont light up , the model has "Home and OK  " button in the middle , thanx in advance .
bd
Is it a promax, if so there is a video on YouTube how to turn on.
Try pressing and holding each button singly for 10+ seconds, if that doesn't work try doing the same with a few combinations of two buttons. If that doesn't work... hit it.
I assume its batteries are good?
Hi Bazz, call Satking on 039553399
But first check all connections. It sounds like you may have an earlier model judging by the placement of the buttons. Does it have a reset button?? It should be connected to the van 12v system.
-- Edited by Magnarc on Thursday 20th of October 2022 11:46:58 AM
It is better to keep your mouth closed, and let people think you are fool than to open it, and remove all doubt.
Samuel Langhorne Clemens,
aka MarkTwain.
Is this it?
yes , found the problem thanx for replys
bd
 And the problem was, for those that may encounter a similar problem?
shakey55
Yes Bazz, it would be nice to know what was the cause, whether the replies were of any use???????
aka MarkTwain.
