SmartBar Camp Creative
Post Info TOPIC: Precision driving
Precision driving
Age does not weary us, makes us go travelling more
KJB
Southern Cruizer wrote:
....or if the other driver did not turn up for work......
KB
Or in Australia we would take the wheels and tyres off and they would be one load and the machine would be the other.
I guess doing it that way would save some crane hire.biggrin
Rob
Chairman of the Bored
A bit like this. The inner rear wheels removed (dump truck facing backwards).
I just had a thought about chaining that unit onto two independent trailers.
Now I wont sleep tonight. biggrin biggrin
Rob
                  This one has a driver in the motorised jinker at the rear. Cheers
Going around a bend, the outside red truck would have to drive faster than the inside red truck.
 Even so the turning circle on the "Rig" would be enormous - (worse than a Y62).
 Because the BIG truck has been loaded over the collapsible front section of the trailers, and seems to be jammed hard against both the front and back sections of the trailers, it is going nowhere. Neither truck would be able to get ahead of the other and any slight difference in distance  travelled would be absorbed by tyre scuff, much as a part-time 4wd with diff locks does when it is left in 4wd and makes a sharp turn on a hard surface. Cheers.
P.S REAL BIG gear from around 1980s.
-- Edited by yobarr on Sunday 16th of October 2022 12:57:24 PM
