Post Info TOPIC: Diesel heater problem..........help needed
We have a Webasto diesel heater installed a couple of months ago under a bench seat with a inlet for drawing air from inside in our MH.
Over a period of 2 nights we accidentally operated the heater with an obstruction in front of the intake vent.
The heater now works fine in every way, it turns on and heats and when turned off it turns off and goes through the cool down procedure as normal.
The problem is, that it appears to not have enough heat coming out of the vents and does not warm the MH like it did.
My thoughts are:
Carbon build up.
A faulty temp sensor located behind the seat.
If there is carbon build up has anyone ever dismantled a heater to clean and how is this done?
Traveling day today, off to Tuncurry NSW so I am hoping for a solution from your great collective of experience and knowledge.
Thanks
Glenn
I don't have an answer to your problem, but here is a copy of the Webasto Airtop 2000 Workshop manual which may help.
Ken
-- Edited by kgarnett on Thursday 1st of September 2022 08:58:24 AM
Thanks Ken I have that manual but it lists nothing........thanks
There are lots of You tube videos on Diesel Heaters.  Faults Maintenance etc.
Try this one just picked at random from YouTube, I have not actually looked at it but it might lead you on to other information sites.
https://www.youtube.com/watch?v=zLwHhiFicko
Mike & Ellie
When you turn the heater on a high temperature setting, and its cold, does the fan speed increase to the max, as the heat output gets warmer.
If it does not, you could well have blockage in the input vent/tube ( or fan vanes in the heater) that is restricting the airflow, so the temperature sensor is keeping the heat down.
Has it generated any error codes?
As Peter mentions these heaters monitor for over temperature and restricting the airflow would cause that but the heater should cope or shutdown, I cannot see an obvious reason why damage should occur. I wonder if by chance a fuel fault has developed which is restricting output? Unlikely but possible.
I never run mine overnight, it's hardly necessary in Australia, buy better bedding.
No error codes have shown themselves. The heater heats up but not to the set temp, fan blows as usual.
Could the temporary blockage have caused carbon build up?
Thanks so far for the responses
Glenn
I would not have thought so. Combustion chamber air and exhaust is separate from heating air so even if the unit was running hot it would simply reduce its burn rate but stay within its minimum parameters which should exclude any possibility of carbon build up.
Are you sure you are not imagining a problem? Easy to do in such circumstances.
Ok, this where I could tell you all that a goat ate my homework or I can own it.
So here goes:
The heater is situated under the dining bench seat, hard to access, so I wanted to get some guidance before I pulled the heater apart and cleaned the excess carbon.
After spotting the blocked inlet I assumed the worse so I went down that road not looking forward to the really tricky job ahead.
After opening up the bench seat all became very clear to me.
After a very rough road trip from Bathhurst to Newcastle on back roads with the biggest potholes ever, the Motorhome got one hell of a shake up.
Turns out that just about every flexible pipe connected to the heater had come adrift.
All tighten up now and the heater is working 100%.
So thanks to all for the help and advice.
Note: I can still use the goat excuse at a later date.
Glenn
KJB
So here goes:
Glenn
Great  outcome.......always good to hear about a simple successful "problem fix" - hope you tightened and supported  everything so it does not happen again......  Long live Diesel Heaters.....!!    KB
KB
Excellent result Glenn!
It is so easy to go down rabbit holes when fault finding.
Glad it's sorted.
RE: Diesel heater problem..........help needed. I cut
Happens often because those pipes do not compress no matter how you tighten the hose clamps I cut a 20mm long slit in the pipe to allow a bit of movement and that solved the problem
Hi. New here. Has anyone posted how to set temperature on Chinese diesel heater please? I can't fathom out the 3 button LCD control panel. Thank you
And as a newbie, can't see where to start a new topic or question, sorry. Help please. Thank you
Hi Yellow Van, welcome to the forum. The issue with setting the temp has been brought up previously and the answer seems to be you can't, most just set it to lowest setting and open a window.
To post a new topic, there is a panel on the top right hand side, just under calendar, "start a new topic". Ian
Status: Online
To start a new topic ....
On the forum Home page click on the appropriate sub forum heading (e.g. Techie's corner"). On the right hand side there should be a button Start a New Topic. Some forums don't allow new members to post for a while as this helps to stop spam. Not sure if Grey Nomads has this feature.
To answer your question about the controller, do you have the one with coloured graphics of the heater components? Here are the notes I made:
Operation
Status
Press OK to cycle through the options
Current temperature
Target temp (large degrees symbol) change if required with up/down arrows
Battery voltage
Error code log
Time
Prime the device
Press OK and down arrow together
H Of displays (pump off)
Press Up arrow to turn on (pump light turns on)
Auto turns itself off after a while or turn off with down arrow
Starting
Press Power button
Animations display
Fans come on slowly
Fuel pump comes on after delayed start
Ignites
Bars increase as furnace temp increases
Turn off
Squeeze power button
Off flashes
Displays glo-plug symbol
Pump switches off after a delay
Takes about 10 minutes to totally shut down
Pair the remote
Press and hold UP and OK for 3 seconds
Screen will show HFA
Press UP to match the machine??? (It will pair?)
It will reboot.
-- Edited by Are We Lost on Saturday 24th of September 2022 10:53:36 AM
Okay guys my We asto is on but blowing cold air, any suggestions. I have removed yellow fuse but still blowing cold air green light on all is running well apparently just cold
GB
Also under the motor home floor there is a tick tick noise
GB
OkY so now i have found ticking stopped so i put that down to it starting. I have one lower in bed room blowing plenty of heat and three others blowing cold. A y ideas please?
GB
Gary, I assume you only have one Webasto heater, which is connected to four heat vents - If so, the problem would be in your distribution pipes (tubes).
The pipes are usually pretty easily crushed/damaged or having circlips dislodge - check out the distribution pipes. Check if there is a control (flap) that is designed to shut off one or more pipe.
Thanks, Guru.
I'll check this out this weekend. I was thinking it possibly could be something like that, but it doesn't hurt to ask that's for sure.
GB
and the ticking is the fuel pump some noisier than others .............
KJB
Loud ""ticking" is often because of the way and position  that the pump is mounted......
KB
The ticking is the fuel pump.
If it is not ticking it is not pumping fuel.
If it is not pumping fuel it will not be heating.
How loud the ticking is depends on how and where the pump is mounted.
What is the model number of the Webasto?
-- Edited by Peter_n_Margaret on Friday 30th of August 2024 10:43:00 AM
You can buy quiet pumps on ebay for around $25, much better than standard
I would have to look through paperwork for model number 2016 is the motorhome.
Found somewhere along the line somethjng has gone up and smashed the Ducting as the larger one is groken in half and one small 60mm pipe is sucked in and closed,
Will replace all this and hopefully all good.
Thanks again for advise.
GB
