Post Info TOPIC: Van window scuff removal.
Does anybody know of a product that will remove or reduce scuff marks from the Perspex windows?
I have tried Vuplex but not successful.
Thanks.
Dick.
Brasso or toothpaste & touch of water & elbow grease. Don't use a mechanical polisher. Get the slave to do it!
You will not remove the scratches, but simply polish them so they are less visible. A problem I had with architectural model acrylic covers to tidy them up. It does come up well, but it is based on elbow grease input.
Headlight restoration kit from supercheap, fixed my 40 year old motorbike fairing screen, has a polish & spray on sealer, Joda
J. Price
Thanks for reply. I thought of toothpaste and brasso but maybe a bit harsh. I might check the headlight restorer.
It's more of a graze from a tree branch.
Thanks again.wink
Dick.
Tree branches are a nuisance , often happens after a long day behind the wheel . Recently scraped paneling on side of our van
Try all of the above remedies though
I have taken to using a reciprocating saw to deal with nuisance branches ( good source of firewood)
Phil
Unfortunately, the trees are at the front of ours and the neighbours house.
I try to keep them trimmed, being in an over 55s lifestyle village, the roads are probably wider than you would normally come across.
 I try to keep as close to the gutter on entry to the front of our house. Went a bit close on one occasion. The things are still growing. I consider the original landscaper planted the majority in the village too close to the gutters
and overhang the roads considerably. Another word to our Assoc Committee needed.wink
Dick.
Rub with 600grid wet sand paper block and detergent. Then rub with cutting compound .
-- Edited by Aus-Kiwi on Monday 1st of August 2022 06:11:53 PM
I believe Novus Compound is good, although I haven't tried it myself others have recommended it to me, it is on my list of products to get when I get around to it.
It is on the net, the link is too long to put up just search Novus Compound
RichardK
-- Edited by RichardK on Monday 1st of August 2022 12:02:06 PM
RichardK Landrover Discovery 3 2009, AOR Matrix Camper
I had very bad scuffs on all my widows
while brasso did help ,in the first it did not get them all out
I ended up sanding the scratches out
I started with a 2000 grit wet and dry 125mm hook and loop pad
I then wrapped around them a foam sanding block
( those black ones from Bunnings ) this gave me the grip to hold the disc
I then progressed to a 3000 grit wet and dry hook and loop 125 disc
this i did wet with a little dishwashing detergent
finally finished with a complete rub over with a fine car polish
they now look like brand new
bob
125 mm 3000 grit Sunmight D532 Wet & Dry Hook & Loop Disc
