Post Info TOPIC: Water hose connectors
We are having leakages at the hose connector on Jayco. Tried everything brass fittings etc. everyone else just hooks up and thats it. Not us always a puddle on that side. Any recommendations on fittings. Thanks
Hi Maz49
If you are talking about the hose connection, which is on your Jayco to be permanently attached to a caravan park, water tap
Then just be aware that this thread, on most Jayco permanent inlet water connections, is an American thread
And that normal Australian water hose connection threads, will be either a BSP or MM thread, and will always leak
Below is a picture of the American thread, (which fits my Jayco Conquest), available from Bunnings, and perhaps available from other shops
Note that it says American Thread in the description, and that the Item Number (at Bunnings) is, 3111033
Hope that this info is useful to you, and others, with a Jayco motorhome or caravan
If this is not the leaking connection, you are talking about, then a picture would be helpful
