Post Info TOPIC: Camper trailer slide out stove problem
hi all
i havent been on here for a while and after some help if possible please
i have a southern cross camper trailer with slide out kitchen .the issue was the flexi hose coming
from under the stove to the bayonet plug at the rear of the camper had to be tucked up under the
stove and by doing so the steel mesh on the flexi hose frayed so when connecting it was like hundreds
of needles so decided to take stove top off to replace the flexi hose,,,, thats no problem as it came off easy
and can now replace the flexi hose ...the issue is the stove top was fixed with sikaflex and not really very strong
and needs to be fitted more securely with clips somehow if possible a new stove isnt an option
maybe as its a chinese import the stuff used wasnt good quality
so i need to fit the stove top somehow so wont move and if needed i can undo again
to replace battery for igniter or if i ever have to repalace the flexi hose again
the sikaflex around the flange of the stove top isnt very big so doesnt grip too well
can anyone help please thnks in advance
brimhunter
I would bolt it down, thus needing an High Speed Stainless steel drill bit, probably 2 sizes. To get them need to go to a dedicated tool shop, that sells the upmarket electric. battery tools, and drill bit's etc. Bunnings don't have them, as I have tried them before.
Ric - The Eccentric One
