Post Info TOPIC: Power to Bed lights
Power to Bed lights
Can anyone advise why I don't have Power To Bed lights on an Erin A Van 2003?
Also No outside light?
Thanks
Imo Two options ? Use seperate battery with LED lights ? Or wire in lights with its own wire ? Can be off inside light circuit as the load is very low with LED lights .
If you join the Avan Facebook group you will probably get your answer there.
G'day Greg,
Firstly welcome to this forum - I hope your time here will be informative, helpful.
Your question - there could be various reasons from a blown fuse, a dry or loose joint, a screw that has entered & broken the feed wire.
You don't say anything about the history - has it worked before? Is the battery, power supply ok?
If you haven't got a multimeter, get one - you can get good, average meters for around $30 from places like Bunnings, Jaycar, other electrical/electronic shops.
ConsumerMan's suggestion is worth following it up.
There is an old saying "KISS" - it's amazing how many of us get caught by making faults dif ftficult!
Yes may find getting outside working may cure ? Fuses ?? Earths !n
