Post Info TOPIC: Theford Toilet not flushing
The flush is not working on my C range Thetford toilet, plenty of water, I'm told there is a fuse located under where the cassette is located, with the cassette out I cannot see this fuse, is there such a fuse, anyone else have this issue. Would like to solve the fuse issue before changing the pump, the impellor is not stuck, checked that first.
Johnnz
Fuse is left hand side up near the top of the plastic wall about 200mm in the cassette compartment.
Thanx Patrol, checked cassette compartment location you mentioned know fuse there.
Johnnz
Right hand side, still trying to attach photo
Email me and Ill send you a photo Nunny63@outlook.com
Cassie, have yet to receive your mail, I have looked extensively in the cassette compartment I cannot see a fuse.
Johnnz
Please send me your email address and I can forward the photo
The fuse will most likely be blown. Cause will be that the pump in the bottom of water tank will be seized. You will need to replace it. Doable but not easy.
