SmartBar SmartBar
Post Info TOPIC: Sealing roof on top
Sealing roof on top
Recommendations on best silicone/sika to use on caravan roof please ? Will be cutting hole to insert Dometic DRS and want to seal properly. Thanks
Sikoflex. Dont use silicone .
Agree
 Which one?
My preferred material is "Bostik seal and Flex" see Seal 'N' Flex® 1 | Polyurethane Sealants | Bostik It is used by quality caravan manufacturers/repairers, as it will allow cyclic flexing when cured. Not the cheapest "Caulk" just the best.
-- Edited by Possum3 on Friday 11th of February 2022 10:54:16 AM
 Amen brother!!
Thank you all !
 Yep, that's the one recommended to me by the Caravan Repairer at Cabolture Qld.  It did an excellent job on my van roof and still good after >2 years.
 X2
Then if you want ? Use a top quality paint to protect from
UV and seal even better .
-- Edited by Aus-Kiwi on Monday 14th of February 2022 09:47:49 AM
Ended up going with the Bostik seal and flex - did a great job. Have had some heavy rain since and dry as a ........................well you know the rest ! cheers
Great !! The main part is being pro active is fixing these things ! No point running into van repair on every little issue !!
