Post Info TOPIC: Rear Tail Lights not working
My Right Hand rear tail light cluster doesn't work.
The front side marker works but the rest of the right hand side doesn't work
I pulled off the cluster and found the green wires were rusted in their connector which I cut off and re connected with a new connector
The cluster is tail brake and indicator none of which work when connected
I have tested each light and they work
Could I have a faulty earth connection ?
Aust Standards say Green coloured wire is for earth when using AC (249V.
Earth is usually Black for DC (12V).
As very few manufacturers follow Wiring Standards - The 12V cable is cheapest with disregard to Standards with regards to Gauge and Colouring.
Back to your question you most probably do have a faulty Earth connection - Try a substitute piece of cable attached to bumper bar or such to see if you can get current flow.
You don't say what vehicle you have - that would help with diagnosis.
Do you have a towbar? Often the towbar connection takes it feed from the R side taillight. Maybe the wiring takeoff is crook.
Does the blinker light work on the R side of the vehicle? If it does, it effectively rules out a bad earth.
Depending on the vehicle, it is possible that each taillight is fused, and you may have a blown fuse.
DOEs the brake light work on the R side of the vehicle? If it does, again the earth is OK.
Check the 7 pin (or 12) trailer connector, a good clean out and a small screwdriver to open up the pins slightly.
Check for voltage at tug and at the tail light at rear of van.
Cheers Bob
Make it Snappy......Bob
 If your car is a CAN bus system, a wrong LED globe somewhere can create problems.
"Earth is usually Black for DC (12V)."
Except where it is usually white;
https://www.narva.com.au/resources/trailer-plug-wiring-diagram.
Pin No.CircuitWire Colour
1Left-Hand TurnYellow
2Reversing SignalBlack
3Earth ReturnWhite
4Right-Hand TurnGreen
5Service BrakesBlue
6Stop LampsRed
7Rear Lamps, Clearance and Side Marker LampsBrown
Hi keninnsw,
Welcome to the forum - I trust you will enjoy your time here.
There's some good advice above - as the other wires had rust on them, you can bet that the earth too is rusty somewhere. Can you run a long earth wire from your van-car plug to your light cluster? I had an issue with my Trailblazer fridge once & I was using the car's body for the 12v -ve (earth) - running a separate wire to the fridge from the battery fixed it.
Also beware - a lot of caravans use the standard 12v colour code ie black is 12v +ve , white is is 12v -ve. Possum is partially correct - if the wires are red & black.
Happy hunting (you may need an assistant)!
Thanks to all those who answered.
I have tested the socket on the vehicle and all was ok
I have opened the caravan plug and everyhting is clean tight and waterproof.
I have a green wire connected to the RH flasher and it works.
When it stops raining I will test the brown and red wires to make sure there's current there
"I had an issue with my Trailblazer fridge once & I was using the car's body for the 12v -ve (earth) - running a separate wire to the fridge from the battery fixed it."
That's a very common issue. You just cant rely on the body to work well as an earth.
Suggest you look under the van for a "common" earth. If you find one clean and tighten. Caused me all sorts of issues with my electric brakes.
Good luck, stuff like this can take forever to find.
-- Edited by oldbloke on Saturday 5th of February 2022 05:51:32 PM
Sta
Check polarity if one side is not working . If they are LED globes ? Other than that . Its usually high resistant connection . Not that theres much load with LEDS .
Status: Online
3Earth ReturnWhite
5Service BrakesBlue
6Stop LampsRed
Caravan internal wiring internationally normally is Black Positive and White Earth.
Aust trailer plugs/sockets use White as Earth.
My previous Jayco Poptop was wired Black(+) White(-). Normal US standard.
See the source image
Cheers, Richard (Dick0)
Status: Online
If the whole cluster is not working check continuity of the Negative from cluster to plug. Had the same problem. Rusted negative return.
