check out the new remote control Jockey Wheel SmartBar Mackay Festival of Arts Renogy
Post Info TOPIC: Remote Control Batteries
How often do you check your assorted remote control batteries?
Just had a well known brand fail on me, the black top with gold bottom. Less than 2 years old, but used most days. Maybe use the mute button too much.
Cheers Craig
Struth! Two years for a remote battery. some marriages don't last that long mate. Maybe you better go rabbit hunting.
Keep safe up there and I'll try down here mate.
Dougwe I believe Craig has not specified what the remote was controlling, could it have been the remote for some kind of robot wife, they could have very complex moving parts.
Ha de ha Pete,
(No mute buttons need for 50 year partner)
but it was a replacement unit for main tv, and on checking records, the same brand killed the original remote. So a slow learner in my later years.
Found OEM batteries in 2 other remotes, one pair around 4 years old and ok, 2nd set at least 10 years old and still test fine. Both of these not used a lot.
Cheers Craig
We tend to frequent coastal locations so that could have contributed a bit, but we had to replace an expensive aircon remote because of corroded batteries, just on two years old. Since then, we remove batteries from all our remotes (aircon and TV) while the van is parked, out of use.
-- Edited by watsea on Saturday 8th of January 2022 08:01:53 PM
