Post Info TOPIC: WDH, Air Bags and/or Increased rear Spring Capacity.
Permalink Closed
I can understand the necessity to use a WDH on a SUV or a Passenger car, they being designed primarily to carry persons and a couple of suitcases in comfort, i.e. soft suspension. But the Utility vehicle is designed to carry a load on the back. The average ute can have Driver, fuel and still have a one ton load sitting on its tray, and according to the brochures is still safe to drive. When I was working, the utes we had regularly had permanent loads on them that made the back sit well down. With our OH&S laws, not to mention traffic safety, surly if these vehicles were not safe to drive, then they wouldn't be on the road.
So I cannot see why a tow ball loading of 350kg, even though the vehicle may be down at the back, would have its steering or stability effected if as the brochures say, it can be driven with a one ton load on the back, so a WDH would not be necessary.
Permalink Closed
An empty ute is usually a bit too light at the back for good handling. I know my Ranger benefits from some weight in the tray, particularly noticeable in the wet. With a small van, the weight on the towball probably helps. But 350kg, and the leverage effect means closer to 500kg extra on the rear axle, while at the same time, reducing weight on the front wheels.
When you add extra stuff in the tub for a longer trip away, you soon get close to the maximum rear axle loading, while the front will probably be reduced from its empty weight. The balance has now reversed and the front is too light in comparison. The front/back need similar weight on them for similar surface grip.
If a tail wag commences, unbalanced front/rear weight loadings make it more difficult to control.
However, most discussions on this subject usually focus on static loads. It's on the road that you really notice the difference. With a heavy van, the difference in road feel between no WDH and having one is like chalk and cheese. Without it, when you pass over road undulations the porpoising effect is very noticeable. At those times the loss of traction on the front wheels is substantial. With a WDH fitted the porpoising is very significantly damped, thus maintaining tyre grip on the front better.
There was a video posted here a while ago showing the vehicle's front wheels actually becoming airborne while overtaking on the highway. No doubt improved loading would have helped, but it highlights the situation.
Air bags and spring upgrades may reduce porpoising, but not as well as a WDH.
Permalink Closed
 Agree. What some fail to realise is the rear axle acts like the fulcrum of a see-saw. So when you add weight to the rear, even with spring or air bag upgrades a lot of weight is still being lifted off the front wheels compromising steering and braking. IMO People who opt for the upgrade often do it because they are too slack to rig the WDH everytime they tow.
Sta
Permalink Closed
 I recorded that video. I could see no evidence of a WDH.
Permalink Closed
So I take it that if I buy a ute off the show room floor, as I go to drive away, the salesman will caution me "Take it easy on the corners, its a bit unstable when empty". How ever if I put a load on the back, about a ton, not including the driver and fuel, the vehicle is now too light at the front to be safe. Oh come on, its a commercial vehicle and is designed to work, if it was unsafe it would not be allowed on our roads. 350kg tow ball weight will become about 450kg at the center of the tray, measurements taken from the center of the front axle 4.6m x 350kg /3.58m = 449.72kg, so the tow ball weight over the rear wheels will be even less.
The loading, or rather the over loading is a different matter.
Permalink Closed
The Ute with a supposed 1 tonne carrying capacity is designed for that load to be apportioned in front of, over the top of and behind the axle, not hanging 300mm out from the rear of the vehicle.
Add to this the "lever Effect", many of these utes having a greater rear axle over hang than many SUV's, this exacerbates the problem further.
Speaking from experience (3 laps with a V6 Diesel Navara with upgraded suspension 215 kg Ball Load), I would never tow without a WDH. The difference in road handling, car and van behaviour and comfort, is like chalk and cheese.
If you upgrade springs sufficiently to alleviate "tail drop" once you "hook up", and utilise that as a sole solution, then the ride of the vehicle when not towing is choppy and uncomfortable. When towing without a WDH the steering is vague and the vehicle feels less stable on the road.
I have tried it both ways and IMO a WDH wins hands down.
Permalink Closed
Iana, you took my post as black and white ..... dangerous to drive when empty, dangerous to drive when fully laden. That is far from what I said or meant.
Vehicles are a compromise. The Ranger is designed to be a compropmise between capable workhorse and family car. I believe it's a little light in the back when empty, and a little heavy in the back when laden to capacity. And as Bomurra says, the load must be distributed, not just all in the back. The rear axle limit of 1850kg ensures this. I certainly don't expect it's best handlng to be when loaded to capacity.
I am guessing that if the designers set it up with perfect weight distribution when empty, it would not have the payload it does.
As for your measurements, I assume they are theoretical, and I have not measured the distances to verify them. However, when I put my 320kg drawbar load on the towball, the rear axle weight increased by 480kg and the front wheels lessened by 160kg. That was measured at a weighbridge, with 2 passengers, extra fuel and water, and loaded to the full 6000kg GCM.
Permalink Closed
iana wrote:
So I take it that if I buy a ute off the show room floor, as I go to drive away, the salesman will caution me "Take it easy on the corners, its a bit unstable when empty". How ever if I put a load on the back, about a ton, not including the driver and fuel, the vehicle is now too light at the front to be safe. Oh come on, its a commercial vehicle and is designed to work, if it was unsafe it would not be allowed on our roads. 350kg towball weight will become about 450kg at the centre of the tray.measurements taken from the center of the front axle 4.6m x 350kg /3.58m = 449.72kg, so the tow ball weight over the rear wheels will be even less.
 Ian,how on earth did you decide that 350kg towball weight will become about 450kg at the centre of the tray? The tray is not affected in ANY way by the towball weight,with all weight added to the car's rear axle.With many utes,a 350kg  towball weight puts around 500kg onto the car's rear axle, with the extra 150kg coming OFF the car's front axle.This weight can NEVER be fully restored by a WDH, for two reasons.The first is that a percentage of the weight that a WDH removes from the car's rear axle is transferred to the van's wheels.The second is that removing more weight from the car's rear axle than was added by towball weight will dramatically increase the risk of oversteer,where the rear of the car slides sideways when cornering,or from the effects of yaw.Sorry,but I have no clue what you are trying to show with your figures.The only two figures needed when calculating weight added to the car's rear axle are the car's wheelbase,and the towball  overhang,or distance from rear axle to hitch point. Cheers
Permalink Closed
As for your measurements, I assume they are theoretical, and I have not measured the distances to verify them. However, when I put my 320kg drawbar load on the towball,the rear axle weight increased by 480kg and the front wheels lessened by 160kg. That was measured at a weighbridge, with 2 passengers, extra fuel and water, and loaded to the full 6000kg GCM.
The figures you've supplied show that you've a good understanding of the physics involved here,although weighbridge increments may affect accuracy.Ranger cannot SAFELY tow more than about 2900kg ATM van because of the lightweight 1850kg rear axle and 6000kg GCM figure. The axle figures of the car,added together,are 3330kg,so there is a little bit of 'wriggle room'.SAFELY tow 3500kg? Not a chance,in my opinion.Cheers
-- Edited by yobarr on Monday 13th of December 2021 10:40:54 PM
Permalink Closed
Add to this the "lever Effect",many of these utes having a greater rear axle overhang than many SUVs, this exacerbates the problem further.
Hi Bob.The comment highlighted above needs to be qualified by people knowing that while TBO may be more,this is more than compensated for by the wheelbase generally being longer on utes.For example,the much vaunted but over rated LC200 has a stupidly short wheelbase of 2850mm, while the LC utes have wheelbase of 3180mm,or a HUGE 330mm (12%) difference.My car,loaded to 3650kg and towing my van,with a GTM of 3150kg, never moves an inch when passing or being overtaken by roadtrains with 3 or 4 trailers,because it has a good wheelbase. Like you,I have played around with a WDH because I was convinced by people who know little that I MUST use one,but it soon was discarded,and now lives quietly in the back of my shed.If you buy the right car in the first place,you don't need to use a WDH in an effort to make the car do things for which it never was designed.Cheers
Permalink Closed
Well, if you purchase a van of a sensible weight you don't need to buy and modify a tractor in the first place. I'd certainly never buy a LC rough rider. I like a bit of comfort and Ute that looks decent, and doubles as a family car, not like an old tractor.
Everyone should buy a Triton, bloody great all round Ute. I certainly feel safe with the WDH fitted when towing. Beats riding in a ute with the suspension of an old bullock dray and chespr than an upgrade made up of cheap leaf springs, 1920s technology.
Cheers.
https://youtu.be/7RYpJAUMo2M  Go rocky.  smile
Sta
Permalink Closed
Now for the truth. Laughs aside.
All non-believers need to watch this video in its entirety.
Using air bags, and I believe heavier rear springs does level the vehicle, however the rear axle takes most of the load and front axles the weight is significantly reduced resulting in compromised steering and braking. So the problem is still there.
When a WDH is fitted the weight from the rear axle is distributed to the front axles and the trailer. It also levels the tow vehicle. This restores steering and braking back to normal.
The scales prove this beyond doubt.
youtu.be/XBZu39pQ8Gg
Dont pay for useless rear spring upgrades or air bags.get a WDH and understand how to adjust it.
youtu.be/4DC-lfNnKf4
It's a shame we don't have ant "qualified" people here to answer questions on this subject.
Sta
Permalink Closed
 It will take me hours to point out the inaccuracies and self-promotion in the WDH v Airbags video,so not just now.The WDH video,with tape measures etc,is nearly 8 years old,and contradicts some of what the first video shows,so that too will take time to sort.Just to get started,how on earth does connecting a trailer to a car,with a nett drop in car body height of 1 9/16",add 215lb to the trailer axles,which have increased from 3785lb to 4000lb? And then we are told that,when the airbags are inflated,suddenly the trailer's axle group has lost 90lb,down to 3910lb,but is still 125lb  above the "baseline" weight? The whole video is a joke,not believed by even the  smaller of the two men in it.(Body language) And their total weights give different figures throughout the video.Later.Cheers
Permalink Closed
Yobarr, you just can't admit you made a mistake getting a rear end upgrade that does very little if anything to correct the problem of less weight on the ront steering axles.
If your sooo, good show us, don't say you don't have time. You keep telling us your an expert.
Sta
Permalink Closed
If your (you're?) sooo, good show us, don't say you don't have time. You keep telling us your an expert.
 Neil,could I respectfully point out to you that NEVER have I referred to myself as an expert,but I do have a bit of knowledge gained from many years dealing with weights and measures.Understanding simple physics,and having a but of common sense certainly help me.These qualities may be foreign to you,but all I ever do on this forum is try to help people understand the basics,despite sometimes being contradicted by well meaning,but misinformed,members.Seems some never will learn,but when I first joined mmy comments were often met with derision.However,over time,members gave realised that I do know what I'm talking about,and have contacted me by PM for help, which I have been happy to give.Whether you understood or not,I do not know,but previously I have explained that all I did to my car was arrange to have the respective axle carrying capacities (1480kg and 2300kg) combined to give 3780kg GVM.As for your suggestion that I have "less weight on the front wheels",I still have 1350kg there.How much do you have? Unlike many lightweights,this car was designed for heavy stuff,and I can run at 6800kg GCM,legal on all axles.Saying that the common twin-cab utes can "tow 3500kg" or even 3000kg for some, is ridiculous in the extreme,if SAFETY is of any concern.MANY times I have explained the physics involved here,so I will not elaborate.If you don't yet understand,you never will,or I can only surmise that it is because you don't want to understand? As for your claim that I said that I "don't have time",once again you've failed to read my post.Does the word "Later" mean anything to you? Already I have briefly outlined the inaccuracies in the video,and once I get my Diesel heater sorted,I will elaborate.But,once again,could I point out to you that never have I referred to myself as an expert.Hope this helps you to understand? Cheers
-- Edited by yobarr on Tuesday 14th of December 2021 02:03:06 PM
Permalink Closed
Gee  I need to remind you again. This is a space bar. It's the red thing.
BTW the scales don't lie.
Sta
Permalink Closed
Now ! Now!, no sparring on this thread, or I'll summon Dougewe to sent you both off to the naughty room corner (opposite corners) :)
I tried to work out where the fulcrum points would be to calculate the moments with the tow vehicle, and concluded that there are so many varying variables it would blow my mind.
Permalink Closed
Thankyou for this exceedingly  helpful comment.At least I can spell! Before you go off on a tangent about "the scales don't lie",could I point out that this obviously is a self-promoting video,and the total weights (GCM if you like) vary throughout the weighing process. The difference,without wasting too much time,is at least 140kg,so all credibility has gone.The "Engineer" never looks comfortable,but most times simply nods in agreement with the other chap,who possibly is his Boss? The WDH video is a joke, has been around for eons,and its advice is contradicted in the Airbags v WDH video, but no doubt it will provide comfort for those who want to feel good,but don't  really want to know their weights.Cheers
-- Edited by yobarr on Tuesday 14th of December 2021 03:03:03 PM
Permalink Closed
 The fulcrum is the rear axle,Ian,as no matter where weight is applied to the rear of the car,it pivots around that axle.There are simple formulae for all such calculations,but I will not confuse the issue.Cheers
Permalink Closed
Yes the fulcrum is about the rear axle, but unless its a wishbone type suspension, the wheel base dimension will move as the load is applied, the rear wheels will move back, so its a variable.
-- Edited by iana on Tuesday 14th of December 2021 04:56:27 PM
Permalink Closed
iana wrote:
Yes the fulcrum is about the rear axle, but unless its a wishbone type suspension, the wheel base dimension will move as the load is applied, the rear wheels will move back, and then go inverted ! so its a variable.
What you say,Ian,is correct but the variance would be so small as to be almost immeasurable,maybe 1%. Similar system on caravans,where axle movement creates roll understeer or roll oversteer,which is a major pitfall for those who think that switching from underslung to overslung springs is a good way to increase ground clearance.Cheers
-- Edited by yobarr on Tuesday 14th of December 2021 04:38:55 PM
Permalink Closed
Well if the fulcrum is the center of the rear axle, or the point where the rear wheel is on the ground, I am still at a loss to see how "are-we-lost" ball weight has increased so much. Quote: However, when I put my 320kg drawbar load on the tow ball, the rear axle weight increased by 480kg and the front wheels lessened by 160kg. That was measured at a weighbridge, with 2 passengers, extra fuel and water, and loaded to the full 6000kg GCM.
Permalink Closed
Your, you're are interchangeable mate. At least I can use the space bar.  smile
The age of the video is totally irrelevant . BTW it's a fulcrum, so no matter what you do to the rear springs, weight still comes off the front wheels. Simple physics. Think see-saw or levers. biggrin
Sta
Permalink Closed
Those words are NOT interchangeable. "Your" denotes ownership,while "You're" is an abbreviation for "you are".       You're wrong.
Pathetic.When have I ever suggested anything different? If your vehicle is so poorly set up that a miserable 130kg difference in front axle weight is the difference between life and death,perhaps you should consider a better,more suitable car,or a smaller van? But seems that,slowly,you're learning a little bit about weights.Keep up the good work.Cheers.
Permalink Closed
The increase in the weight applied to the rear axle,in your case,is 50% more than the towball weight. This is about average,which is why cars with small TBO (towball overhang,or distance from rear axle to hitchpoint) have less weight added to the rear axle,and are inherently more stable,and safer.Cheers.
-- Edited by yobarr on Tuesday 14th of December 2021 06:19:21 PM
Permalink Closed
Mate you seem to have difficulty using a key board and understanding to basic physics of cars. The key board has a space bar. Suggest you use it. biggrin
The rear Axle is a fulcrum, think levers and see saws. No matter what springs or air bags you install, if you add weight to the tow ball weight MUST come off the front axles. Scales don't lie, and the age of the video has nothing to do with the very simple physics. Claiming it's old is clutching at straws. smile
Are you saying Hayman Reece has been lieing to their customers. The WDH distributes the TBW to the front axles and van axles. Something heavy springs can never do.
Here is some additional info for you about levers.
You should have bought a mighty Triton.
Screenshot_20211214-175122_DuckDuckGo.jpgScreenshot_20211214-174701_DuckDuckGo.jpgScreenshot_20211208-170141_DuckDuckGo.jpg
Sta
Permalink Closed
oldbloke wrote:
Mate you seem to have difficulty using a key board and understanding to basic physics of cars. The key board has a space bar. Suggest you use it. biggrin Provided that my posts are easy to read,and easily understood,I see no need to use your "space bar". Throwing in a Red Herring in an attempt to distract from your crumbling position in this debate is pathetic.
The rear Axle is a fulcrum, think levers and see saws. No matter what springs or air bags you install, if you add weight to the tow ball weight MUST come off the front axles. Scales don't lie, and the age of the video has nothing to do with the very simple physics. Claiming it's old is clutching at straws. smile Regarding fulcrums,levers and seesaws,when have I ever claimed anything  different? You claim that "scales don't lie",which may or may not be true,but accurate reporting of the readings may not always occur. Without wasting too much time dissecting this self-promoting video report,I already have found 140kg of inaccuracies. My intention was to write a detailed report on every stage of their weighing process,but since you do not understand even the basics,I feel that I would be wasting my time.Rote learning is a proven method of teaching,but it works best when people WANT to learn.Arguing your point from a losing position is pointless.
This is becoming monotonous.When have I EVER claimed anything different? If you care to study my posts from early in my membership here,you will see that when I first wrote that weight was added to the van's axle group by a WDH,thus increasing total weight (ATM if you like) I was shouted down by one and all.Subsequently I was proven right,so you have at least learned that.
 You should have bought a mighty Triton.When referring to cars,putting "Triton" and "mighty" in the same sentence is ridiculous.They're a "dime a dozen",and probably overpriced at that.
Permalink Closed
Here are screen shots of a couple of posts from the "early days",where my claims have been ridiculed by a senior member of the forum,and several others.There are many others if you would like to see them? This was before they realised that what I wrote was correct.All is good now though.Cheers
P.S I'm off to the pub now,so may not reply to further posts today.
-- Edited by yobarr on Tuesday 14th of December 2021 07:18:10 PM
Permalink Closed
 I had a fresh look at the figures. The weighbridge had 20kg increments and it was at a dump site, so a couple of readings differred by about 20kg when calculating totals. The actual measurements were:
So the towball load of 340kg resulted in 500kg increase on the rear axle and a reduction of 160kg on the front. Once the WDH was adjusted, it transferred 120kg off the back wheels, distributing 80kg to the front wheels and 20kg to the van (yes, the raw figures show a discrepancy of 20kg).
The figures in red are where the loads were over the limit. It was packed to the gills with full van tanks, extra water, spare battery, fuel, beer and provisions, and would very rarely be driven like this. The weighing highlighted that I needed to get rid of a few things.
Permalink Closed
Gee hope you hope your drinking habits are better than your space bar habits.
Some safety info for you here.
https://youtu.be/4DC-lfNnKf4
Sta
