Post Info TOPIC: Failure of flexi pipes can cause major water damage
I saw this article in the news and thought that it would also apply to caravans:
Flexi pipes are a cheap plumbing hardware for your home but could cost you thousands
https://www.abc.net.au/news/2021-12-02/the-hardware-that-can-cost-you-thousands/100666628
failure of any pipe carrying water could cause damage
shortly after i got my 1st van, the drain from the sink was convoluted pipe. i used to keep a very sharp knife under the sink on the shelf. one day i sliced straight thru the pipe without realising
i replaced the original pipe with pvc drain pipe. problem solved
Started as " eazy hooker ", but like most things now made in covid land and many imitations
Cheers Craig
