Post Info TOPIC: Avan
Avan
I'm looking at buying an Avan the seller says the rubber needs replacing. He has the rubber but hasn't installed it. Is this a big job. I haven't viewed that Avan yet as it is 4hours away
It is a very awkward job, if you haven't got anyone to do it for you, and are not adgile enough then, you would have to pay someone to do it, but a caravan repairer should be able to reseal it. Maybe at a guess up to a grand to get it done.
-- Edited by Bicyclecamper on Monday 29th of November 2021 03:39:42 PM
Ric - The Eccentric One
Are you talking about foam rubber sealing strips?
Status: Online
No not a very hard job, worst bit is the Apex roof ridge seal. Even that I find is not all that hard.  But that bit might not need replacing ?
I have done my van twice over the years and helped others to replace their Roof/Wall Seals.
Do one strip at a time.  Remove and replace as you go. Noting/mark, where the ends are for when you put the new one on
Scrape old seals  off using a Sharp Scraper (or sharp wood chisel) and an adhesive remover. I actually just use WD40 and Meths (for Cleaning)
Use the meths and wire wool or a Green Scourer to clean the area before sticking the new seal on.
When satisfied do another one.
Take your Time.
Join your local Avan Club members can be a great help and source of know how.
Mike & Ellie
