Post Info TOPIC: The SOG Toilet Ventilation System
Has anyone had experience or have one of these , do they work and any problems thanks
Search SOG on this forum and you will get plenty of information.
Cheers, Richard (Dick0)
Thanks Dicko shall do
Only one problem that I have ever come across.....
If the fan is too close or not high enough above the cassette, it can get some contents of the cassette into it in challenging off road conditions. Not a good scene if it happens.
 Great bit of gear,but as Peter has said,it is important that you ensure that the sh-t does not hit the fan! Cheers
Thanks for your advice will keep that in mind
