SmartBar Camp Creative
Post Info TOPIC: Making a (home brew) cider??
Does anyone make a cider (home brew) with success?
After many years I still can not "get it right"
I use "Black Rock" tins.....with 1lt apple juice with varying amounts of malting sugars (from 750gms to 1.5kgs) ..........and have left a brew to ferment from 7days to 2 weeks.
Our  temp range is 25 degrees to 37 degrees....ATM (which should be good for home brewing)
Some batches are flat..........some blow up every bottle.........some blow up a few bottles and some (very few) are OK. .
Any help appreciated
cheers Bilbo
Seems you need to gain control of the fermentation process, do you use a hydrometer and allow the brew to ferment out before you bottle?
Santa.
Back in the days when I was brewing home brew (beer not cider) we used 2 litre soft drink bottles. Put a teaspoon of sugar in the bottom of each bottle and then added water to the ring mark - about 50mm up from the bottom. The water stopped the home brew taste and bottles were easy to come by and did not explode. Easy to sterilise and seal - no worries about crown seals
Good luck with your cider
 Hi Greg. Believe me,Doug has mastered the homebrew beer! He makes a great drop,and it is hard to stop drinking once started! Cheers
Bilbo, my quick google reckons your temps are too warm, nothing over 21 is desirable
Cheers Craig
Temp variation is far too much IMO.
Do a reach here. Should find some info.
www.diybeer.com/au/customer/account/login/referer/aHR0cHM6Ly93d3cuZGl5YmVlci5jb20vYXUvY3VzdG9tZXIvYWNjb3VudC9pbmRleC8%2C/
Sta
Thanks everyone.
I cant do much about the temps but I will invest in a hydrometer.......plan "B" might have to be that a certain lady has to drink beer.
cheers Bilbo
bilbo wrote:
Thanks everyone.
cheers Bilbo
 Bilbo, temp is very important. You need to find a way to  control it within 2 or 3 deg.
Sta
maybe even a cheap bar fridge, also look at brewing in " post mix containers " which fit nicely into the bar fridge
Cheers Craig
oldbloke wrote:
bilbo wrote:
Thanks everyone.
cheers Bilbo
 Not sure,but perhaps Doug is referring to ambient when he says "25-37". Cheers
Yep, some put the fermenter in a fridge to ferment. Even have thermostatic control.
37c is way too hot. It will kill the yeast. That will result in in complete fermentation intern resulting in exploding bottles.
Sta
