Post Info TOPIC: Dmax cab 2018 height standard
Hi anyone out their that has the Same model Ute with the 5 spring rear set up. I cannot find any info on the standard height from centre of wheel to the wheel arch body. If anyone can provide these measurements that would of great help to me. Rear and front. Cheers Scoota
Cliffs
Ozisuzu is a forum with plenty of Isuzu information. Its members just love their vehicles, justifiably or notbiggrinbiggrin.
Thanks Ill look them up. Only I have just had My rear leaf set re set and 2 new leafs added and fitted with shockies and wow it looks high at the back. From centre of wheel to underside of arch was 520 before with about 200kg in tub. Know its 570 to 575 and the front was not touched and is 510.
Cliffs
Forgot to say front was 520 before.
Cliffs
why would you want to upgrade the ute i believe the manufacturers know more about building there utes than anyone on this forum if the vehicle you have is not fit to do the job you want to do then get the right ute if an upgrade mwkes the ute better why would the manufacturer not make it that way
 Take some deep breaths boab thats not the answer the op is after
JB scorpion sting 206
travelyounger. Correct Cheers
Cliffs
Actually I have just found a really good past post on this forum regarding suspension if anyone is interested. The heading is DMax 11/18 suspension Post Reply
Cliffs
