SmartBar SmartBar
Post Info TOPIC: Tap flow poor how to fix?
The spiggot type  water tap over the sink in my van was reduced to a dribble.the fix is replace the under sink water filter folks
Now I can fill the kettle in under a minute
Phil
 I had a water flow problem in my van a while ago after it was not used for a while.  It turned out to be blocked filters, the ones about the size of a five cent piece which screw on the end of the tap itself.  They all had a calcite or sand build up.  Washed them out and bingo.
I had the same problem, but only after I had replaced the anode in the hot water system and given it a good flush out.
More careful how I do this now.
-- Edited by bomurra on Wednesday 27th of October 2021 07:57:14 PM
