SmartBar SmartBar
Post Info TOPIC: Screws keep falling out.
Hi All ,Im having trouble with the screws falling out from the bed surround (Avida Esperance) which is made from a high density rubber (i think)
Is there some way of fixing these screws so that they won't keep falling out.I have tried glueing a match in the screw hole then replacing the screw
but the screws just don't want to hold.
I will try to attach a photo.
Blues man.
Just to be clear, your screws are screwing into high density rubber?
There are a few fixes. One is to use bigger screws.
The other is to drill new holes either side of the existing ones (be careful to only drill the aluminium and not the under structure.) Then use additional screws to secure the two pieces.  This is the way I would go. It looks like there was not enough screws for the job in the first place. Double the number in fresh material may be a bit more successful.
Is there something below the rubber you can screw into? If so, use longer screws. If that means you will have the points of the screws exposed in a position where you will get spiked, use machine screws with nuts and washers
-- Edited by PeterD on Sunday 10th of October 2021 11:36:32 AM
Can you post more pictures, what is it, what does it do ?
Blues Man,
Are all of the screws falling out? There's no way of getting something behind the rubber to screw into, I guess. Or do the screws have to come out at some time? If not, could you add contact glue to the threads??
buy a tube of Soudal Ultra Repair Adhesive (available fron Mitre 10).
Squeeze it into the screw holes and tthen screw the screws in do not touch until its cured
 Thanks iana ,the thing i'm trying to fix is the skirt (10mm high density rubber)which goes wright around the bed ,to make it look pretty when bed is down
One photo is with the mattress on and the other is with mattress off.
The bed lifts up to expose a storage area under the bed and the skirt covers the area between  the bed and storage area
Hope that makes sence.
tn-2432756?AWSAccessKeyId=1XXJBWHKN0QBQS
/download.spark?id=2432757&aBID=51933
Blues man.
Warren-Pat_01 wrote:
Blues Man,
Thank you Warren ,there is no need for the screws to ever come out because the skirt is a permanent feature
I am thinking maybe i should drill all the way through the skirt and fix it with a small nut and bolt type fixing ,which has a nice domed stud on the outside
of the skirt.
Blues man.
Yes Corndoggy ,the screws are screwing into the high density rubber skirt ,but because the skirt is on 10mm thick ,and we don't want
the screws to come our the other side there is not a lot of meat for the screws to screw into.
I possibly could leave it as is but put another 40 or 50 or 100 screws to hold it but i think they will still eventually fall out over time.
Blues man.
Still doesn't make sense to me, I think one of those pictures is 180 degrees about. What about a couple of pictures further out showing what it does. Like does the mattress lift up, and that is a storage space underneath.
Patrick, is this what you have? - Avida Esperance. The trim below the mattress looks to a chromed metal extrusion in that shot. Securing your rubber piece there with bolts (hex head) would look a little ugly. That's why I suggested a machine screw above. Select one with a nice pan head like the original screws and use acorn nuts to secure it.
-- Edited by PeterD on Monday 11th of October 2021 12:07:37 PM
Thanks PeterD,that looks very similar to our M/H. I do like the idea of using acorn nuts ,thanks for that  suggestion ,i never thought of that
Looks like the photo of that Avida in your post does not have the rubber surround like ours has, like i said the rubber surround is just to make it pretty.
Now that i  know what i have to get i will search google to see which one will suit best.
Thank you .
Cheers, Blues Man.
Blues man.
I have found Sikoflex works in so many ways ! Maybe another plastic cover and small nuts and bolts to sandwich them together ?
Thank you to everyone of you who took the trouble to answered my post. Now off to the think room.
Blues man.
