Post Info TOPIC: Outback Dunny
Outback Dunny
This one is in the Flinder's Ranges stays in the memory.
I presume the "hot" water is solar heated in the tank? Sounds like evening showers would be preferred :)
I have been studying the "Ėngineering" of the unique ablutions hut. I note the "Southern Cross" branding on front of door (a great Australian company). I assume the flat gal sheets were originally the envelope (tin-box) sheets that the corrugated gal sheets were in when originally delivered, I used to utilise these sheets for making useful metal things myself (still have a toolbox in the shed) - waste not, want not. As it was about 24# SWG it was considered rubbish by most, it was greedily accepted by this young teenager for many projects including several tin canoes.
Back to the original post: I assume the plastic tank to be a cooling tank for bore water - a lot of weight for a flimsy structure - hot water would be direct from capped bore. Solar panel on roof would supply power (stored in battery) for 12v pump.
Alan, if you have any further photos of the structure or plumbing arrangement, I would like to see them posted. If you can recollect any other pertinent information regarding it, I imagine others would also be interested.
The square shaped pan is indicative of a long drop - Is that the case?
bel.jpgbel4.jpgbelt1.jpgSorry I can't help with the workings,I really didn't pay much attention to the way it worked.
It was at Old Beltana. We planned to stay a few days,but in the morning the sky was full of black rain clouds,so we moved on.
-- Edited by Plain Truth on Tuesday 7th of September 2021 03:00:00 PM
We haven't spent too much time around Old Beltana and Leigh Creek but merely passed though and camped overnight a couple of times with LRPBS - When this Lockdown is over we do intend on spending some quality time in SA, so I will be certain to investigate further.
Thanks for your reply.
Has any other GN's spent any time around this area?
maybe 3.5 tonnes of water in that tank, sitting on 50 x 25 rhs and old corrugated walls , I think a sponge bath sounds better
Cheers Craig
Do they store the doodoo in that tank PT winksmile
