Post Info TOPIC: Removing Staples from Aluminium Cladding
I am removing the siding from my caravan to do some repairs. Around the edges of the cladding, the manufacturer has used staples in addition to glue/silicone to affix the panels.  What is the best way to remove these staples so as to cause minimal damage to the aluminium?
Ric
Lever them out with something over panel so it doesnt damage ! Masonite etc ?? Gives better mechanical advantage as far as leverage also . Often used a screwdriver sharpened from one side so it slips up staple !!
Thanks for that.
Welcome to GN's bushsong,
Aus-Kiwi's methodology is spot on but use a small sharp wood chisel (not screw driver) buy a pack of 4 for about $12 at El-Cheapo Shops.
Yes I found wood chisels I have too thick . Why said to grind down one side screw driver . Even a few rubs on concrete is enough . Horses for coarses and common sense !!
Leaver up one side of the staple at a time.
Did you make that? I can't find anything similar with a Google search. Thanks for all the replies too BTW.
Ric
Had it quite a few decades.
A quick workaround, maybe a small cold chisel grind a curve on one side. I would still put something under to spread load as others have suggested.
Ric
 Mechpro Blue Pry Bar Set 4pc - MPBP101K
Mechpro Blue Pry Bar Set 4pc - MPBP101K | eBay
