Post Info TOPIC: TV swivel Bracket
TV swivel Bracket
Bought the van with this set of screws where possible a previously tv bracket was
Would like to purchase same bracket with same configuration as the screws in the picture.
Would anybody know what brand would suite have difficult in finding on line ?
Dimension of screws 100H x 60W
VESA monitor swivel bracket. Maybe Jaycar or Officeworks has the right configuration. Failing that make an adaptor plate.
Paulp hi,
I maybe able to help you out but not for say 2 weeks. I think I have spare one at home.
My base is Brisbane.
Thanks Radar
For the offer will keep u in mind
Paul
 Thanks for the info Will do more research maybe take out the 3dprinter and make a adapter plate
Paul
You could duck down to your local aluminium welding engineering workshop in an industrial area. They probably have a small offcut of say 3mm sheet or 100 x 3 flat bar should be large enough. Scrap metal merchant maybe or off a council pick up, that's where I often get good pieces of aluminium.
https://cdn.shopify.com/s/files/1/0683/1931/products/CUZZI-DW120B_12_inch-Wall-Monitor-Mount-Specs_large.JPG
https://www.amazon.com/LCD-Mount-Swivel-CUZZI-D177A/dp/B0017RAGDG
http://1-computerdesks.com/pdf/CUZZI_D177A.pdf
As already stated, it's a VESA compliant hole pattern.
-- Edited by dorian on Sunday 1st of August 2021 10:55:16 AM
Hi Paulp
Most places which sell TV's, would also sell TV wall brackets
One easy way out, would be to make a paper template of the 8 hole spacings
Then just go along to JB HiFy/Retrovision etc, with the template, and buy the one which matches your hole pattern
This might go close.
www.australiandirect.com.au/buy/kickass-12-volt-caravan-tv-mount/KATVMOUNT
Might be hard to find something exact. You could drill new holes in a bracket or as said make some sort of adapter.
-- Edited by Corndoggy on Sunday 1st of August 2021 06:18:21 PM
Thanks it looks like the one
But is it a fixed wont be able to take down easily for travel ?
paul
That looks like the one.
Maybe you could drill a bigger hole just below each existing hole, so that the screw heads could pass through the holes.
This one does not swivel but take a look.
www.ebay.com.au/itm/164310342038
