Post Info TOPIC: Jayco poptop ceiling water marks
Hi everyone
my jayco poptop has developed roof leaks and has subsequently left water marks on the ceiling inside. Does anyone know of a way to get rid of these internal water marks? The ceiling is Formica type materia.
I have heard that water leaks on poptops can be a problem.
Snubby, If you have a leak in the top section of a pop-top it should be repaired as soon a possible - watermarks will be the least of your problems, they can be cleaned off later when roof is repaired with either Ajax or Painters Soap.
After the roof leak fix, would try a Frig white spray if that colour matches
