SmartBar
Post Info TOPIC: Russian Truck for Motor Home base
AAV 4x4's Brett Bolton is hoping to offer a motorhome version of the Gaz Trackmaster within two years, similar to its Fuso Canter 4x4-based Global Explorer, but at the moment its available as a fully-equipped tray back straight out of the box.
"(The motorhome) will probably be built on the long wheelbase version, because the dual-cab and single-cab actually have the same tray, so the dual-cab is just that 800mm longer, so it means we can build a motorhome on the dual-cab chassis but using the single-cab,"
Tough Russian truck for work or play - trucksales.com.au
-- Edited by Possum3 on Monday 26th of July 2021 09:12:08 AM
Looks promising but if I were in the market I'd be concerned about spares and the servicing ability of regional/remote mechanics?
KJB
 In general,being Russian , it is probably relatively Spartan, Simple and Tough  compared to some other vehicles which tend to be Flash, Complicated and Fragile......
-- Edited by KJB on Monday 26th of July 2021 03:37:36 PM
KB
I am led to believe that LDV (a Chinese vehicle), has been made into a motorhome, by a mob in South Australia
I know nothing of this vehicle.
I do agree that while travelling Australia, (on bitumen roads), it would be much better to have simple engine vehicles, than a fancy and fragile one
I have been reading too many stories, about modern motorhomes going into limp mode, which would be inconvenient for the owners
Our 1994 Perkins powered OKA has one wire that makes the engine go or stop, and I KNOW where that wire is :)
Using Mr Google
It looks like OKA is starting up again, and making customised motorhomes, (4x4 and 6X6), in Perth WA
Using Cummins engines
Link to website below
https://www.caravancampingsales.com.au/editorial/details/legendary-oka-motorhomes-return-125439/
Tony Bev wrote:
It looks like OKA is starting up again, ......
Maybe? smile
