SmartBar
Post Info TOPIC: Winegard Antenna
Winegard Antenna
Is there a Winegard Antenna that doesnt wind up and just stays in down position ? I dont see a winder handle on the inside. New van for us and I didnt get all the nitty gritty. Thanks
Is the TV working? I am unaware of any antenna that cannot be raised. www.rvpartsaustralia.com.au/product/winegard-tv-antenna/
 This one looks more like this style. Ill have to have another go at tuning it in etc. Only tried briefly.
 Like the attached
Opps I was going to ask if it was a winegard, according to your picture it looks like a winegard
When I brought my second hand motorhome, the winder handle was missing, and it was hard to spot where it should have been
-- Edited by Tony Bev on Wednesday 7th of July 2021 09:38:50 PM
 Yep, I have the specs that say Winegard..Ill have another look inside for handle, but would be fairly clear to see on the ceiling, directly under it I thought ??
Rob, I am trying to make out what you are asking. Are you wanting to purchase an antenna or are you asking about the one you already have? Winegard does have antennas that are fixed to the roof that do not extend but they are not readily available in Oz. I have seen the one in this link occasionally - Marine Amplified Omnidirectional Outdoor HDTV Antenna
You blokes posted whilst I was preparing my reply. Do you have a handbook for your antenna? If not we can find one for you to download. If you have the handbook I suggest you read up on the 6 monthly service routines.
There are parts for Winegard antennas here.
Thanks guys. Its a 5 year old van and yes, there is an antenna up there and I was told its fixed and does not wind up. I was unaware of any that didnt wind up and there is no manual. I will take a couple of pics tonight and update.
Anything that is stamped or embossed on it would be of assistance (if you can climb up there.)
Bit of a goose chase. I was given specs of winegard antenna, but turns out its an NCE model OMD2013-White which is an amplified antenna, that has no handle for winding. See attached pic and thanks for your help.
-- Edited by RobDor on Thursday 8th of July 2021 04:14:22 PM
Make sure you have the amplifier plugged in ? One of mine has 240 to 12v amplifier. It needs the inverter on just to run it ! I will be getting a 12v booster so dont have to use inverter !
We have one of those NCE things on our 5 year old van roof.
To say they are useless is an understatement! If you watch tv a lot, you will need to replace it or go satellite.
We just stream Freeview or Netflix  to the laptop or iPad.
Ha ha ! Thanks for that. Havent had a chance to use yet, but dont watch much anyway. Streaming on line the way to go
 What did you replace it with? If it was the standard Winegard T antenna I would not have expected it to have performed significantly better.
 The problem with NCE antenna is that its fixed to the roo. You cant raise or lower it, and you cant rotate it. Supposedly its an omnidirectional antenna and should work, well, in any direction If you happen to park and its facing the right direction of the tower, itll work fine with the amplifier on, but otherwise its useless.
PeterD, the T antenna is very underrated, I have one on my shed at home and it works like a dream!
