Post Info TOPIC: Pre heating hot water for instantaneous gas hot water system
We are on the road at present doing what I refer to as our  Spangled Drongo run, as it is the only bird that flys south in the winter. We are finding that in places our Camec instantaneous hot water system cant quite deliver a hot shower. As they are designed to heat up to 37 degrees above the temp of the incoming water, where it is exceptionally cold and the incoming water is in single figures we can at times only get 40degrees out of the unit. I was wondering if anyone has had this problem and solved it using a portable instantaneous gas hot water heater to preheat the incoming water. I was thinking of something like setting up a unit with a bayonet connection and running the cold water into it and then into the van water inlet at the lowest temp setting. Of course this wouldn't work when running off the tank and pump unless I altered the plumbing coming into the Camec, which is possible. Has anyone tried this? Any ideas?
Cheers.
G'day Peter, Welcome to GN's.
I have heard others complain about the delivery of hot water from instantaneous heaters, unfortunately I know of none that have had a solution other that to change water heater to Gas/electric unit or diesel heated units.
How hot do you want your shower water?
I have a domestic Rinnai Instaneous HWS in my van and set my shower water temp to 39 which I find comfortable any temp above 40 is starting to get too hot for me.
Ken
-- Edited by kgarnett on Wednesday 7th of July 2021 02:30:08 PM
Do the opposite of what we did in southern France. We put the bottles of water out at night to cool down so we had cool thermal mass during the 43°C days. It worked well, nice cool wine.
So keep a container of water indoors overnight so it's warmer in the morning.
Run it on cold . Then when slightly heated come through? Itll feel hot ! Third world issues ! Lol
Feed a small amount of the hot water output back into inlet side of the pump.
Ken
-- Edited by kgarnett on Wednesday 7th of July 2021 01:03:21 PM
Thanks Ken. That is worth investigating. I will have a look at the plumbing when i next get the time and see what is involved.
Depends on line pressures ?
Yes, cutting back pressure increases temp but we have been places where the water is so cold we cant get the pump to run properly on such a slow level. Been looking into this a bit more and it comes down to the camec being undersized. It only develops some 35000btu whereas a more expensive Truma unit can produce up to 60000. You get what you pay for $1k as opposed to $2.5.
At home we have two 3 phase electric 20kW instantaneous hot water systems. They heat water up by X amount. In summer we switch them to only run off 2 phases at they get too hot.
Your options are to start with warmer water or to slow the rate the water goes through the unit.
Hi all; Had a problem with the hot water heater after i changed the sacrificial anode and hardly any hot water out of any of the taps. The problem may be the tempting valve ( this valve mixes hot and cold water together, so as the hot water only is not to hot to scald you. The problem was the small screen in the tempting valve was partly blocked and needed removing from our caravan, cleaning ( was easy outer the caravan than in ) and reinstalling. No problems since.
Stephen, is not yours a storage water heater? The OP has an instant one.
Coming in a bit late here because Ive only recently signed up . . . .
I had the same problem so I bought a 2000 watt instantaneous electric hot water heater which I plumbed into the inlet line servicing the gas hot water heater. The electric heater has a regular cord and plug so no wiring in required. Tested on its own, the electric unit made the water tepid but, with lukewarm water rather than icy cold water feeding into the gas unit, I have strong, hot water in the shower. And, in warmer weather, I simply unplug the electric unit.
Thanks mein. That is exactly what i needed to read. Think i will do the same but with a portable gas heater. Im also going to insulate the hot water pipes. Cheers. Peter.
I have seen copper pipe bent around exhaust to heat a seperate tank . Relying on thermal to circulate. Heat tank .
Good idea. Will have a look at whats involved with doing that. cheers.
I wonder, the hose from the pump to your instantaneous hws, if that had a short 400mm section of copper pipe that sat on top of the heated air of the hws it would preheat the water.
Have a "T" piece so in warm weather it is disabled.
Tony.
Thanks for the suggestion. Combination of lock down and bad weather and the caravan being more than 5k from where I am means I wont be doing anything for a while but that is another good idea I will check out. thanks.
