Post Info TOPIC: Towing Level
Towing Level
Question on van level when towing please. Had the van a week and still trying to get set up right. I have read you should get the car and van on a level surface , unhitch van , get the van level with jockey wheel, measure from ground to point on tow hitch on van and do same measurement to same point on car, and they should be the same. I hope thats correct ? So, question, when you hitch the van, isnt the tow ball weight going to bring the van height down a little bit up front, hence the van will dip a little ? So, is that ok, or should the van be level when hitched up as well ? Should I use a variable height tow ball hitch to get the van level when hitched up ? Any advice appreciated. Cheers
Starting by measuring the heights before connection is a good idea, but it's the level when connected that matters.
The goal should be for the van to be level, or slightly nose down, but never nose up. This is more important if you have dual axles and non load sharing suspension.
If the car sags down at the back substantially and raises at the front when connected, you are affecting the handling characteristics of the tow vehicle. A Weight Distribution Hitch would help. But if you provide actual measurements and weights you will get a lot of help to work out if any action is needed. Read the Weights and Measures section up the top of Techie's Corner.
-- Edited by Are We Lost on Wednesday 30th of June 2021 02:49:54 PM
Ok thanks for that. Just got a tow ball weight scale delivered today, so will be doing over the next couple of days. Will come back with actual measurements. Cheers
Welcome to GN's RobDor, you can download some basic information free at www.caravancouncil.com.au/
 Good information in this post,particularly the first sentence.."It's the level when connected that matters". You could add to that sentence "When loaded,ready to travel". However,if  the van is dual axle,and has non-loadsharing suspension,it needs to be as level as possible,with slightly lower pressure in the van's front axle.This allows that axle to "shuffle" when cornering,as opposed to it being the the effective pivot point if the front of the van is down,and the tyre pressures all are the same.If you could advise what car you have,and the model of your van,including its ATM,we may be able to offer more specific advice.Lastly,a word of warning! Towball scales are,at best,a rough guide,in my experience.As an experiment,I once purchased several different brands and compared their readings.The difference in readings was ridiculous,with none anywhere  near what the actual weight was when I paid to have my towball weight checked.All these units were subsequently given away to people I don't like,with the exception of the most accurate,which lives somewhere in my shed.Cheers.
This is an example of a VERY poorly set up unit!
-- Edited by yobarr on Wednesday 30th of June 2021 07:04:04 PM
-- Edited by yobarr on Wednesday 30th of June 2021 07:04:39 PM
Thanks for the info. I havent had a chance to do any measurements yet, but I can tell you the car is the new model BT50 XTR auto, dual cab 4x4 and the van is a 2015 Millard Breakaway Longreach 1660, single axle with ATM of 2600 and tow ball rating of 210, wheels are 265/75 R16. At the moment I have 54 psi in van wheels, but may have to come up to about 60 psi. I will be measuring hitch heights when van is level in the ne t couple of days.  cheers
 Good car to tow a van such as yours,with its 2600kg ATM. Forget the towball "rating",as it likely means nothing more than that being the towball weight of the van at the factory.With 2600kg ATM you should be looking at around 260kg (10%) towball weight,but first check your owner's manual, as some AUTO  BT50s are limited to 250kg towball weight,I believe? With your car's long wheelbase,and your mid-weight caravan,there is no need to consider a WDH,unless you wish to put exceedingly HEAVY loads into your utes tray. A WDH removes weight from the car's REAR AXLE,with SOME of that weight being transferred back to the car's front axle,while the rest of the weight is applied to the van's axle group.This can often result in you exceeding your van's total allowable weight (ATM if you like) or your van's axle rating,or its GTM. ( Gross Trailed Mass,or weight on van's axle group).These figures can be found on your van's compliance plate,and will help us give further advice if you supply them to us? It is vitally important to understand that a WDH does NOT change towball weight.Never has,never will. But it is a seriously misunderstood piece of apparatus.Back to your original question.Your van should be set up so that,loaded to travel,towball weight is around 10% of the loaded weight,and the van is level,or slightly nose-down. Good luck with your set up,but always we are happy to help if you have further questions.Cheers.
                       P.S Just checked towball weights,and there are no problems there,with 4wd auto able to have 350kg towball weight.(In theory!)
-- Edited by yobarr on Wednesday 30th of June 2021 08:02:30 PM
Hi Robdor,
m.youtube.com/watch
m.youtube.com/watch
You may, or may not require a WDH. But many swear by them. And some hate them.
In anycase these videos from haymen Reese will help you understand how they work and how to set them up.
Sta
 If I owned your caravan in my thoughts only, I would be reducing the tyre pressures from 54 psi to somewhere around 40 psi, my reason being those pressures you have mentioned are maximum preasures if your are driving at maximum speed of the tyre rating at the maximum weight of the tyres rating for one hour without blowing them.
So probably 40 or 42 psi would be more acceptable for your caravan. The first thing the caravan will not be shaken to pieces by seriously hard over pressured tyres.
 Initially I thought the same,Ralph,but then I realised that the OP will have over 2300kg on a single axle,so pressures need to be higher. My rule of thumb for those  tyres on that van suggested a pressure of around 60 psi.On my dual axle van,with similar 265/75 R16 tyres and 3200kg GTM,I run 40psi on front axle and 42psi on the rear.Cheers
A little Knowledge is a dangerous thing.
With tyres, any tyres, the size is imprtant yes, but the ONE thing you need to look at is the Load Index.
That is the part that will dictate, what pressures to use at what loads. Maximum load, maximum inflation, just because it says maximum pressure is "X" it doesn't mean you need to run that pressure if the the load does not justify that.
Also the speed rating. 265/75R16 tyres can have multiple speed ratings, from Q, R, S, and T,  also multiple load indexes, which vary from one manufacturer to another, from 109 to 123.
Some tyres may even have two load indexes, one is for single wheel fitment, one for is for dual wheel fitment.
Normaly the higher the speed rating, the higher the maximum speed range, and simarly, the higher the load index letter, the higher the maximum load carrying capacity.
Not all tyres in one size, are suitable for all applications.
Graham Day.
Not all those who wander are lost.
I'm a bit confused. One suggestion from Are We Lost suggests:
"The goal should be for the van to be level, or slightly nose down, but never nose up."
And then another from yobarr seems to suggest that the lower front is bad.
Which is right and why?
Yes Ive done a few calculations on those tyres an that setup. About 60 psi is what they should be.
 If you could point out exactly where you believe I "suggest" that the lower front is bad,I may be able to elaborate.Cheers
 My tyres are 123 load rated,and that is what I did my calculations  on,reaching a conclusion similar to yours.Cheers
As Yobarr responded, "where did he say that?" Of course, taking advice from the internet may be risky. So, how about the NSW official towing information.
Transport for NSW - Towing a trailer or caravan
There is a lot of useful information there. In the second last paragraph it says:
The trailer drawbar should be level or slightly nose down
 The image.
A question for the wise, I have noticed a tow bars with the tongue turned over and the ball obviously, to get a bit extra height to level the van.
Does that compromise the integrity of the hitch? Reduce the weight carrying capacity? And is it legal?
Cheers Bob
Make it Snappy......Bob
Cheers Bob
 Nissan Australia reassured me back in 2016 when I made this enquiry about the use of their towbar, the towball retriever (tongue) could be used either way on our Navara crew cab ute.
There is lots of other things wrote in Nissan owner manual about towing but that was not mentioned hence the phone call.
 The image.
Are you serious? The image shows a setup with a very significant nose down attitude. This is far from level or slightly nose down. The caption was "A very poorly setup unit".  That does not mean a conflicting opinion with level or slightly nose down. But I will leave it to yobarr to say more if he chooses.
So what does it matter if the draw bar is slightly nose up?
Iana, it doesn't matter a rats bum.
In answer to the question of turning the drawbar tongue over, some drawbars have different ratings for which way it is used. This does not apply to all manufacturers but there are cases such as the Ranger and I think the Landcruiser tongues. Wise to read up in your owners manual.
Greg O'Brien
Ok, Ive done some measurements. With the van level and unhitched, the car is 115mm lower than the van (obviously measured to the same point on the van and car). I also measured the tow ball weight at 240 (just using a tow ball scale as indication). So I guess, I need to raise the tow hitch (its a D035 by the way) on the car by 115mm as a start point ? Hook it up, then see how shes sitting ? Your advice is welcomed.cheers
 X2.Good post Greg.Cheers
 Hi Rob. As you have suggested,the first step is to raise the hitch,as towball weight is about right,although you could go a bit heavier there if you wish.Well done on selecting a DO35 too.they're a great piece of equipment.Your car will easily handle 240kg weight,but it is very important that you try to centralise heavy weights over the van's axle,rather than at its extremities.All looks good though,and it is great to see someone acting so responsibly with their weights.Cheers
-- Edited by yobarr on Friday 2nd of July 2021 05:11:20 PM
 Wrong!
Just my two cents worth. I run my 2.6T single axle van 265/75/16 tyres at 60 psi (rated max is 80psi) and that works for me. The van and tug should both be level when hitched up on level ground. Be mindful of the tug axle loads - see the owners manual for maximum front and particularly rear axle loads. Depending on your rig, you may be well within GCM, GVM, TBM and ATM but still overload the tug rear axle if you fill the tray/boot.
yobarr wrote:
 Wrong!
           Right!
Ok thanks, Ill try that.
