Post Info TOPIC: Road and Bridge Weight Limits
Hi fellow nomads,
I have been trying to find information on using roads and bridges which have signposted weight limits. Are the limits based on gross combined mass or actual combined weight? Do you treat the tow vehicle and van as 2 separate units (GVM and GTM)? Secondly are there any maps/Apps that show where these weight limited roads/bridges are. Would hate to spend hours driving along a country road only to come across a 3T limit bridge!!
Mike R
Michael Ringland
When not towing, the relative limit is GVM.
Not sure about when towing, but I expect it is GVM plus GTM.
I have a Garmin RV GPS that does weight and size limits. Without having a look, l'm sure it uses my combined gross weight as the total for roads and bridges and takes me around those. GCM.
-- Edited by STRETCH ARMSTRONG on Tuesday 1st of June 2021 06:29:48 PM
Home is where I park the rig.
Tug 2016 D-Maxine
Den 2009 Goldie RV
As Pete said.
When not towing GVM rating.
When towing GCM rating.
Monty. RV Dealer.
Thanks for the replies
-- Edited by mykringo on Tuesday 1st of June 2021 07:11:30 PM
Michael Ringland
Does the Garmin show the actual locations of the restricted bridges/roads or does it just plot a course to avoid any potential issue? I have just ordered the Hema Australian Truckies Atlas and am hoping that this will show up all restricted locations
Michael Ringland
bgt
Aren't some limits "per axle"?
The Garmin RV is basically a truck GPS but has RV info preloaded.
When l have a destination point it just takes me there via a route suited to my vehicle cofiguration. Towing or not towing. When l dont have a route in the GPS it just warns me about upcoming obstacles.
I haven't had a low bridge warning yet using that configuration, but l have had narrow road and several vehicle length warnings.
-- Edited by STRETCH ARMSTRONG on Tuesday 1st of June 2021 09:02:36 PM
Tug 2016 D-Maxine
Den 2009 Goldie RV
The maximum weight of a car/caravan combination or a motorhome is likely to be less than seven tonnes - mine is about six.
There will be very few bridges in Australia with a weight limit of 7T or less, the only ones I have seen are old wooden bridges on forest roads.
With a six tonne rig if I came across a bridge with a weight limit of 7T I would find another route rather than cross it.
 My GCM is 7.8T hence my concerns about weight limits
Michael Ringland
Thanks for the info, I have just ordered the Hema Australian Truckies Atlas, hopefully it will have the info I am after. We have an off-road van so whilst I am not necessarily worried about standard road bridges it is the typical country road timber bridges that will be more likely to have an issue. I also have seen some local councils have posted locations of weight restricted bridges
Michael Ringland
For anyone crossing a weight limited bridge the figure of your RATED GVM if not towing and your RATED GCM if towing a trailer are great guides but it must be understood and considered that if you exceed any of those ratings and due to the overweight condition of your vehicle or combination you then exceed the bridge limit then you are actually breaking the law.
In the transport industry if you are caught exceeding a load limited regulation then you may be booked for overloading back to the posted weight limit.
In simple terms for example if you have a bridge limit or road limit of 12 tonne and you have a truck which when loaded with soil is legal at 22 tonne GVM and you choose to cross or travel the restricted area then the authorities may write you back to 12 tonne and then charge you for exceeding your permitted weight by 12 tonne, which will result in a massive fine even though on an unregulated section of road you may be legal.
This happens a lot when you drive a road train with a tare of 20 tonne and you may encounter a load limit road of for example 22 tonne which will permit you to travel when empty on that section but once loaded you have to find another route that will avoid the limited area.
What I am saying is just don't rely on rated GVM and GCM but know your actual weight accurately if you are close the the bridge weight limit.
Rob
Rob
Chairman of the Bored
Thanks Rob
Michael Ringland
