SmartBar
Post Info TOPIC: tyre pressures
tyre pressures
does any one use a obd2 wireless tyre pressure unit
your opinions?
You can get solar powered ones that sit on your dash that have nothing to do with the obd2 port. Wireless entirely.
Greg O'Brien
obd2 is the brand. australian company in perth wa completely solar
Thanks to other members of this forum, I'm happy with my Safety Dave unit but I only use it on trips where the need to monitor 4,6 wheels is essential & where under normal circumstances, the pressures won't vary much.
I wouldn't be using it in areas where I had to vary the pressures a lot e.g. HD off road conditions.
Looking at the OBD2 website, their units seem ok, are cheap enough. I've had concerns in the past with solar operated, charged items as the heat eventually cooks the batteries with the worst case scenario being an explosion, & the cases.
I only have a car to do. Have wired the TPMS into the fuse box & with its own additional fuse as the accessory circuit has a 20amp fuse. Easy to do & it's out of the sun.
Both the caravan and prime mover i am looking at purchasing have them as O.E fitments.
My BMW Bike has them as standard, but i did run an after market setup on bikes in the past.
3 to 4psi down on pressure is probably around 10% underinflated, and opens up all of the known issues associated with that.
Graham Day.
Not all those who wander are lost.
When you have pressure displayed you will be surprised just how much pressure changes from a cold morning to a warm afternoon. The sun on one side for half an hour, say on the north side of the car on the Nullarbor vs the shadow side, this alone will be about 3psi difference.
I'd be extremely wary of any automotive brand calling itself obd2.
OBD2 actually stands for "On Board Diagnostic" version 2. It is the internationally standardised communications protocol and port found under your steering wheel that can be plugged into to read error ECU codes etc.
