Post Info TOPIC: Honda2kva/ibis 3 AC
Honda2kva/ibis 3 AC
Is any one using this combination with success
Yes. Very.
You can't have anything else on though including 240v charger and make sure the 240v part of your water heater is switched off at the heater.
Keep Safe on the roads and out there. (Also keep your cool)
Thanks Chief
I have the Honda 2.2 Kva and will run the ibis 3 and the 60 amp charger but it is working hard and noisy.
If just the air is on it runs at approx half to 3/4 revs so I would expect the 2.0 kva to be similar.
Cheers John
JB scorpion sting 206
KFT
G'day
Dougwe is on the money, AC on its own and get a genuine 1.5mm/2 lead just long enough to reach the inlet. Mine is only 5 metres long which helps keep the voltage drop as low as possible.
I turn the Eco throttle off until the AC has been running for a while and the gennie quietens down quite a bit.
KFT
-- Edited by KFT on Tuesday 6th of April 2021 08:07:06 PM
Avagreatday.
Thanks Guru
I was recently loaned a 2kva Honda during a hot day. Started and ran the Ibis with no issues. Was pretty noisy and emptied the 2.5lt tank in 4 hours. So 7.5lts of fuel over a 12 hour run.
-- Edited by Fester55 on Wednesday 7th of April 2021 08:43:39 AM
Ibis 3 and honda 2 works good for me. I use a a 2.5 ml cable just long enough to reach the vans plug.
Joe.
