Post Info TOPIC: Using Reo Mesh for a Frame to Fabricate A Caravan Stone Guard
Have this ticking away in my head as a cheap way to fabricate the frame to support the shade cloth used to make a caravan stone guard.
If viable I will apply protective coatings to the mesh to inhibit the steel corroding.
Thoughts please.
Reo mesh a little weighty just make up a frame border out of half inch square RHS two uprights from A frame cover with Sarlon Meshing - that'll stop bricks.
But if you really want mesh, there are several galvanised light weight versions, sheep mesh for one
Cheers Craig
You can buy stainless reo mesh, neighbour is using some as lattice for plants.
There are a huge variety in the sizes of reo mesh. The finer size would need a frame. Larger size could have some cut out to reduce weight.
Thanks you have confirmed some of my thoughts.
