Post Info TOPIC: Hino Rainbow R145 aircon
Hi. I'm new. Just bought myself a rainbow to be a permanent gypsy. Had a/c unit in at time of import but removed secondary to electric compliance issues. Owners did not replace. I'm told it has compressor on engine and the vent in roof is still present. Recommendations please. I know I need one for when it's hot. Thinking of a diesel heater for cold..... Advise most welcome
S Burke
Welcome to GN's Susie,
Firstly you must consider where and when you will be a gypsy to decide whether you need an air-conditioning unit at all. ie if travelling solely in Southern Tasmania I would suggest not necessary, if travelling in Central Australia, or Northern Australia will you be there in dry or humid conditions. Air conditioning has only become a must have in Australia over the last 30 - 40 years, prior to that we utilised windows, air vents, fans and even clothing choices to remain comfortable.
That being said; if you consider an air-conditioner vital, phone bus wreckers to ascertain whether they have a suitable unit for your Rainbow. Jap Spares used to have a good range of new and used componentry that may allow you the re-instate your existing unit.
Not too many people travel exclusively in southern Tasmania anyway, but some trivial information - I have noticed that over the last week, Hobart had higher maximum temperatures than Ulverstone on the north coast. Weird place is Tasmania.
Susie Burke wrote:
Hi. I'm new.
Sadly, I'm old :)
Good advice from Possum regarding the AC - do you *need* one?
I went nomad two years past and have spent that time in Victoria and southern NSW, I have only used my AC a handful of times on 40C days and even then I could have gotten by sitting under the awning and using a 12V fan. Also keep in mind you need 240V to run an AC so you'll also need a generator or caravan park.
As for the diesel heater? Yes, yes and double yes! :) I fitted an Ebay one ($185) last year and it has been *wonderful*. They make the van warm from -3C to +18C in about 10 minutes and use very little diesel (125ml/hour). The installation is not difficult but if you cannot do it yourself you'll, obviously, need to have it done professionally and the pros will usually only fit the name heaters so expect a final bill of around $2000+ Perhaps try and find a good handyman or the like who is looking for a weekend job and will fit an Ebay unit?
The people on this forum have a wealth of information - do not be hesitant in asking for info or advice.
Enjoy your new life - I nearly always camp in the bush rather than caravan parks and, after two years, have no regrets from adopting this lifestyle.
Welcome to the gang Susie, enjoy here and out in the playground.
If I understand correctly you would have to have the engine running to operate the aircon if you put one back in. It might be worth looking into fitting a 240v aircon instead so that way you have cool air when stationary. You would need to carry a Generator (who said that G word?) to provide 240v when freedom camping. You could always go way out and have heaps of Solar and Lithium Batteries with a big Inverter. I didn't say that 'L' word either.
I have a gas heater fitted to my aluminium teepee but the Diesel is just as good. It's a personal choice thing really.
 Hi Susiesmile
My thoughts. Others have said this but to be clear about using the missing bus airconditioner. If you refitted a unit then it would only be useful when you are driving and the engine is running. It could be a big cost to achieve that.  That is good to have but you usually spend more time parked and sitting or sleeping in the bus, than driving, and then you need a different type of airconditioner similar to a house unit. But they need power to run them and so if you are in a caravan park you plug into the 240V power. If you are not in a caravan park then you do need another source of power to run it. You would not normally leave the bus engine running while parked to get cool air.
There has been discussion about how to get power for an air conditioner, using a generator or big battery bank, please read some of the threads here and ask some more questions if you want. There are disadvantages to these ways to consider. aww
-- Edited by Jaahn on Wednesday 16th of December 2020 08:15:39 AM
could always fit a 12/24 volt compressor pump, best of both worlds
blaze
Thanks everyone, I appreciate the welcome and advise. I naively thought the cab ran the back unit whilst driving. Now I know it's separate and expensive so I can't see the merit in the front unit purely for driving. I bought a portable air conditioner and tent for intimate space when sleeping (to run off solar, drawers 750W). Can't see the point in having a roof unit that requires constant plug in. BUT does anyone know about roof unit and Genie. Looking at a Houghton Bellaire 3400. Can buy unit for $1700 but needs installation and Genie connection?? Clearly I'm clueless. Can that be put on whilst driving or only stationery? Would that unit need a 2 or 3 hp (?) Unit? I do struggle with heat and as this is my home I would like the option to be comfortable. Blaze, in your comment about a compressor unit, could you be more specific please. I have no comprehension on this issue and am seeking clarity. Thanks in advance Susie
S Burke
 Hi Susie smile
Well you came back with some questions so we must have answered something for you. But I am puzzled by the things you mentioned above in red. You should tell me what they are or what they mean ??
But to explain a bit how an air conditioner works. It needs power from somewhere to 'make the cold' and run the fans to blow the cold air around. Quite a lot of power compared to other things. So if you do not want to plug into 240V power then you will have to make your own power. People do use a small generator that produces 240V. You must ensure the generator is suitable and powerful enough to start and run your air conditioner. There has been discussion on this subject.
You could put plenty of solar on the roof and a good battery system to run a 240V inverter. Then you could run a small air conditioner that way. But some matching is required to ensure it will work OK. Just spending money may not be the best way to get a good result. An overall design and plan might be a better approach for a good cool result.
-- Edited by Jaahn on Wednesday 16th of December 2020 10:11:55 PM
 here is a link for a compressor, if you look through the link you caan build up a complete unit and work out pricing. The most efficent type for mobile and stationary for a motorhome and with electric vehicles becoming more popular hey will only get cheaper
https://speedyairspares.com.au/catalog/12v_24V_Fully_Electric_Compressors_Accessories-307-1.html
blaze
-- Edited by blaze on Wednesday 16th of December 2020 10:55:41 PM
speedyairspares.com.au/catalog/12v_24V_Fully_Electric_Compressors_Accessories-307-1.html Just the compressor on 12V draws 50 Amps & at $1100 is not how i would go. Split type Inverter aircond would be a cheaper & more eficient way to go.
D.L.Bishop
Wow, thanks. I appreciate the reply Blaze, (haven't work out how to do individual replies yet, apologies). That is all together to complicated for me.....
S Burke
Hi DeBee, thank you. The split still required a 240v power source, no? I've read a little about them. Is just given I have an existing vent in roof already reinforced I thought that would be easier....I do worry about rust though as that is the site of only existing rust(repaired, but.....). It would seem to be that an onboard gennie would be the best (??) Solution. So last crazy question ( for now) who does that your of work, installing a roof unit and inbuilt Genie to run? And do I need a mortgage? Can get unit for $1700
S Burke
I have existing solar on roof, but I would need 1.4kwh more to ring a small split system, there isn't room (existing vent and roof rack). So that isn't a viable option for me
S Burke
Hi Jaahn, thanks for your reply. I bought a portable air conditioner that drawers 750W which I will run off and independent solar set up, called "close comfort". Just for personal space, approx 1 x 2 cubic meters. The addition of a bed tent creates an exclusive cool zone. Seemed like a good off road alternative. Obviously I'm not sure what to do. But I know the heat kills me (). So I thought it would pay to put a reverse cycle roof unit on (the is existing reinforced vent present) and run off Genie. Just not sure how to organise. I can buy ac unit for $1700. Not sure where to go from here..... Have time, get bus next month and not heading off in a hurry
S Burke
Hi Susi smile
I would not rush into things. Make a plan first. Plenty of time to get it right the first time, rather than getting some unit that might be unsuitable or possibly find another unit that might do two jobs.
If you do not have practical skills or background then you will probably need to get the work done. If you tell us what part of the world you are in then others who have experience might recommend good places they have used and recommend that are closer by you.biggrin
The range of experience on this forum is wide and a lot of years doing things also. So ask away ! Plenty of people here have a genny that they use for air con and other use. Other bought a MH with a built in genny and always use it. Some people bought a genny and then hardly used it after all and now leave it at home. Then there are the solar crusaders who like to free camp without a genny or noise and have systems that will do this too.  It depends on a lot of things and how you like to lead your life on the road. Read the thread here to get some of the discussions and ideas. Also the Solar sub forum above.
PS I sent you a PM on this subject.
Thanks Jaahn. Good advise, pretty much the conclusion I came to. The more I looked the harder it became. So I shall wait.... I've put some funds aside. How do I access your PM? Susie
S Burke
  Hi smile  go to the top right hand corner when you log in and there is a 'button' that has {Logged in as, *****, Log out} Just click on your name there and it will go to your personal pages. If you want to reply the window is already there. Just type and then send.
